gsr is bogging down
Old Jul 13, 2009 | 10:29 AM
jyracer's Avatar
Default gsr is bogging down
i have an obd1 jdm swapped gsr and after i put in a bored out ported and polished throttle body it started bogging down sometimes then sometimes its good. i have a crack in my header and put jb weld on it and after i took tht off accidentally its been doing it, i put some more on it and it still does it. also when it bogs down it shows nothing on my air fuel ratio guage, could it be fuel filter, o2 sensor, fuel pump?? im not sure, any help would b great
Old Jul 13, 2009 | 11:58 AM
S2Integra's Avatar
Default Re: gsr is bogging down
MAP maybe. Bad O2 can cause numerous problems as well. More likely the O2. There is a way to test. Unhook the O2, if it runs better unhooked it is the sensor, if it runs worse when disconnected, then it may be ok but another problem it could be.
Old Jul 13, 2009 | 12:39 PM
jyracer's Avatar
yea i got a dif. map with the throttle body but i lost it or id try tht
mouab18c1's Avatar
get it tuned!
Old Jul 13, 2009 | 12:44 PM
jyracer's Avatar
yea it mite make a difference, the ecu is already chipped with hondata s100 with a 5200 vtec and no revlimiter
Old Jul 13, 2009 | 07:53 PM
jyracer's Avatar
yea i put the different map on it, and after i drove it a little bit it still bogged but once the temperature dropped it ran perfectly
Old Jul 15, 2009 | 09:44 AM
jyracer's Avatar
but it runs like total **** wen its hot out, it drops down and almost cuts off. any help?
Old Jul 15, 2009 | 12:04 PM
kchungb17a's Avatar
Check the TPS on the TB. Or change back to the old TB and see if you have any problems.
Old Jul 15, 2009 | 12:47 PM
jyracer's Avatar
wat volt is the tps suposed to read?
Old Jul 15, 2009 | 01:24 PM
mouab18c1's Avatar
if i remember right its .5 at closed and 4.5 at Wide open
kamwrex
Honda CR-V & Element
Jul 10, 2017 03:34 PM
auto moto
Dec 28, 2005 05:45 PM
Btothe3rdDegree
Aug 28, 2004 05:46 PM
Nick7
Sep 6, 2003 08:40 AM
