fuel leak CEL code 90
Old Feb 25, 2004 | 12:24 PM
SSBP DC2's Avatar
Default fuel leak CEL code 90
has anyone had this problem? I've tried reseting the ecu and swapping gas caps, but after a while the light would come back on...don't know what's going on. if you had the same problem, how did you take care of it?
thanks guys
Old Feb 27, 2004 | 04:37 PM
SSBP DC2's Avatar
Default Re: fuel leak CEL code 90 (SSBP DC2)
bump
Old Feb 28, 2004 | 11:19 AM
brooksto's Avatar
I have had code 90 since my auto to manual conversion. I tried replacing the large canister with no luck. Check the helms, there is some detailed troubleshooting involving vaccuum and voltage checks. I just havent got around to it yet. Also, I think I read somthing about it having to fail twice after starting the car and the system purges before it will throw the cel again.
Old Mar 1, 2004 | 10:45 PM
SSBP DC2's Avatar
Default Re: fuel leak CEL code 90 (brooksto)
thanks...i'll try that
any other suggestions?
Old Mar 2, 2004 | 12:49 AM
Aaron M's Avatar
I just ignored mine and eventually it went away
Old Mar 12, 2004 | 06:08 PM
SSBP DC2's Avatar
Default Re: fuel leak CEL code 90 (Aaron M)
i've been ignorin it for a while now...about 6 mos... and it's still there! The strange thing is it came a couple of days after i put back the stock exhaust setup
Old Mar 19, 2004 | 06:48 PM
jdmhatch94's Avatar
u got an exhaust leak some where!!!! my boy had the same problem
Old Mar 29, 2004 | 12:54 AM
SSBP DC2's Avatar
Default Re: fuel leak CEL code 90 (jdmhatch94)
hm...i'll check on that...but it kinda makes sense since it only came after i changed back to the stock exhaust
Old Mar 29, 2004 | 03:47 PM
geminis2k's Avatar
Have this exact same problem with my car. Unfortunately, it can be a number of things but I'll tell you what Rick Case Acura said made it go off on mine.
Bypass Solenoid Valve. Mine went bad somehow. Getting it replaced this week, check that - but ultimately you will need to troubleshoot it. If not, deal with the code, doesn't hurt you one bit.
teggy2154
May 8, 2008 06:57 PM
B-lue16A_EK
Jan 28, 2006 01:52 AM
G_S_R
May 3, 2004 03:17 PM
notoriousB
Jan 10, 2004 11:51 AM
Goy091
Jul 12, 2003 08:14 PM
