CEL code 90 help
Old Apr 30, 2004 | 04:53 AM
G_S_R's Avatar
Default CEL code 90 help
i just need some input here.
CEL 90 = Evaporative Emission Control System leak detected in the fuel tank area
how can i check for this? i've tried the turning the fuel cap ~7 times. I always do but it didnt fix it.
Ron
Old Apr 30, 2004 | 05:49 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: CEL code 90 help (G_S_R)
I've had that code for like a year.....still drives normal.
Old Apr 30, 2004 | 06:45 AM
G_S_R's Avatar
Default Re: CEL code 90 help (RealTypeR)
so i tried the fuel cap again and tightened it. when i turned the key the CEL comes on for a second, then off for like 1/2 a sec and then back on again. does this mean that its fixed? how do you reset the CEL so it wont come on after.
Ron
Old Apr 30, 2004 | 08:14 AM
disconnect the battery for like 5 minutes.
Old Apr 30, 2004 | 01:04 PM
R6Boy69's Avatar
this code came up for me a couple months ago... I replaced the gas cap and reset the ecu... voila problem fixed...
Old May 1, 2004 | 12:01 AM
jsk62's Avatar
i had this too. just put cap on well, then reset ecu. thats what fixed it for me.
Old May 1, 2004 | 05:22 AM
mikestypeR
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I've had that code for like a year.....still drives normal. </TD></TR></TABLE>
lol the tankeR.
Old May 1, 2004 | 08:43 AM
Black R's Avatar
25 Year Member
I'm glad this topic came up - saved me the trouble of creating my own.
My itr powered hatch was backed into on the left side right at the gas filler door by a less than vigilant driver. The code 90 came up and has been annoying me ever since. I'm guessing that it compromised the filler arm that goes to the tank - or the seal..... The code seems to come and go though - perhaps due to the heat and cold causing the seal to work better at times.
It may be all in my head, but the car seems to run richer with the cel on (code 90).....
Old May 2, 2004 | 08:02 PM
G_S_R's Avatar
Default Re: (Black R)
Thanx for the inputs. I'll just go ahead and get a new cap and reset the ecu. most likely oem cap. any idea on the price?
Ron
Old May 3, 2004 | 09:26 AM
R6Boy69's Avatar
Default Re: (G_S_R)
I just grabbed 3 gas caps from the wreckers with a bunch of other little things. They charged me $20
Old May 3, 2004 | 03:17 PM
K20DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G_S_R &raquo;</TD></TR><TR><TD CLASS="quote">so i tried the fuel cap again and tightened it. when i turned the key the CEL comes on for a second, then off for like 1/2 a sec and then back on again. does this mean that its fixed? how do you reset the CEL so it wont come on after.
Ron</TD></TR></TABLE>
fixing the gas cap and driving 3 consecutive drive cycles will clear the code and turn off the mil.... if u reset the ecm it resets your driving habits.fuel trims.( dosent mean its bad) could even save more gas.!
civic_976
Jun 12, 2010 12:17 PM
Wazup
Jul 10, 2005 11:55 PM
EuN_TeK
Mar 15, 2004 10:32 AM
davidjaii
Nov 5, 2003 03:42 PM
PiYoImuT
Aug 22, 2001 09:59 AM
