Should I rebuild before boosting?
Old Nov 20, 2002 | 11:27 AM
speed's Avatar
Default Should I rebuild before boosting?
I have a stock GSR motor with 110000 mile on it.I want to run 12-14 psi daily...Should I rebuild before boosting?
Old Nov 20, 2002 | 11:47 AM
The_Head's Avatar
Default Re: Should I rebuild before boosting? (speed)
If youre going with that much boost, it certainly wouldnt hurt. I would be nervous boosting a stock motor that much. But, that's just me. My view is on the conservative end on this board.
Old Nov 20, 2002 | 11:50 AM
2K_TEG's Avatar
Default Re: Should I rebuild before boosting? (xThexHeadx)
yes. rebuild it.
Old Nov 20, 2002 | 06:51 PM
speed's Avatar
anymore?
Old Nov 20, 2002 | 07:19 PM
Doogie Howser's Avatar
if the compression is good id run 10-12 boost on it till it blows then rebuild, you never know you might get another 50,000 boosted miles on it
Old Nov 20, 2002 | 07:23 PM
Hammett's Avatar
I would rebuild the engine first for higher boost application.
Old Nov 20, 2002 | 07:26 PM
shermanyang's Avatar
Default Re: Should I rebuild before boosting? (Hammett)
BOOST IT and let it blow!! well, it's not my motor so that's why i'm saying this.
Old Nov 20, 2002 | 07:31 PM
BoM's Avatar
BoM
Default Re: Should I rebuild before boosting? (shermanyang)
boost it first. run low psi
then push up the boost, blow the engine and then rebuild.
Old Nov 20, 2002 | 09:03 PM
skilzz's Avatar
Default Re: Should I rebuild before boosting? (BoM)
yeah install thicker head gasket for that kinda boost and boost away, rebuild later. You have nothing to lose this way.
Old Nov 20, 2002 | 09:50 PM
tegasaurus's Avatar
Default Re: Should I rebuild before boosting? (skilzz)
don't install a thicker head gasket. You're cam timing will be off. Just boost 6-8 psi, till you have the money to rebuild, then boost 12 psi, blow it, rebuild it, love it, tune it.
Old Nov 21, 2002 | 12:26 AM
blufke's Avatar
Default Re: Should I rebuild before boosting? (tegasaurus)
just boost it. maybe not that much but boost it for sure.
Old Nov 21, 2002 | 03:07 PM
skilzz's Avatar
Careful how you say this. You make it sound as if installing a thicker headgasket will damage his motor. Installing thicker head gaskets (and I've installed quite a few) did not make a noticebale difference in performance. It advances it just a hair but not enough to worry about.
Old Nov 23, 2002 | 05:18 PM
speed's Avatar
The motor is not in the car yet.So I can't comp. check it but the motor came out of a modestly driven GSR.Should I just throw it in the way it is?
B16Civic93
Jul 13, 2005 02:12 PM
silverslicks
Feb 16, 2005 10:31 AM
thruvines87
Dec 9, 2004 09:12 PM
Honissan
Jul 15, 2004 01:22 PM
mozez
Jan 13, 2004 08:48 PM
