Start-up Problem
Old Sep 5, 2009 | 04:54 PM
fireflare's Avatar
New User
Default Start-up Problem
Have a 94 integra
I've been having problem starting the car, I can typically start the car up for the first time without problems then if I were to park and turn the engine off for a while and then when I'll be starting it again, it would start but would die right after. I tried pumping the gas right after I turn the engine on, the engine would react everytime I pump the gas but sometimes after I release the pedal it would die again. Other times, I would be able to start the engine up by pumping the gas.
Is the problem with the spark plugs? Or something else? or is my fuel line clogged up?
It's a manual tranny.
Hope you guys could help me.
Old Sep 30, 2009 | 06:18 AM
urithium's Avatar
Default Re: Start-up Problem
I am having some similar issues. It happens very consistantly now. But I have figured out a way to get it to start and maybe this info will give some one a hint to what the problem is. So I was leaving work, started the car and it died as i put it in reverse. I cranked and cranked hoping to get something. I replaced the main relay about 2 months ago, I was getting spark and I could hear my fuel pump power up. The back seat is out of the car at the moment so I have easy access to the fuel pump. I had run out of options so i figured i should do a fail safe test on the fuel pump to make sure it is working. I unpluged the wiring harness on the outer top of the fuel tank. It started up, but of course died as it ran out of gas. So I hooked the harness back up and let fuel system pressure up, un plugged the harness and the started the engine, then plugged the harness back in before it had a chance to die. The problem is not fixed by any means, but I think it being narrowed down to a fuel delivery issue or maybe 02 sensor. Any help?
Old Sep 30, 2009 | 07:44 AM
fireflare's Avatar
New User
Yeah, it is in the fuel delivery system, my friend and I cleaned the injectors and now the car is starting up good.
Old Sep 30, 2009 | 08:27 AM
urithium's Avatar
yeah i have cleaned the injectors but no luck.
Old Sep 30, 2009 | 08:30 AM
fireflare's Avatar
New User
I'll be having my car checked before snow hits, do you think this is also connected to the ignition system?
Old Sep 30, 2009 | 09:24 AM
urithium's Avatar
I think its dumping fuel somehow and is giving the 02 sensor a false reading.
Old Sep 30, 2009 | 09:48 AM
fireflare's Avatar
New User
I just hope you could fix yours too and that mine would run smoothly over winter.
bobmugen
Aug 22, 2012 01:27 AM
steezychristian
Sep 18, 2011 09:46 AM
DJLikwid
Honda Civic (2006 - 2015)
May 30, 2011 09:31 AM
Subzonic
Jun 23, 2003 08:16 AM
