i need help solving problems with check engine light.
Old Jun 14, 2009 | 03:05 PM
CUTTERSPOOL's Avatar
Default i need help solving problems with check engine light.
My car is throwing the code P0302 No. 2 Cylinder Misfire, and P1139 Ignition System. What the first thing I should look at?
Old Jun 14, 2009 | 06:22 PM
Default Re: i need help solving problems with check engine light.
anyone?
Old Jun 14, 2009 | 10:17 PM
sik96teg's Avatar
umm spark plugs, plug wires, distributor cap, comp test
Old Jun 14, 2009 | 11:08 PM
Jimmy's Avatar
Global Moderator
I don't even see a code ''P1139'' listed.. Are you sure that's the correct number?
For the P0302 cylinder misfire code.. Pull your spark plugs and start inspecting.
Try searching?
Old Jun 15, 2009 | 04:57 AM
I will try that first.
Old Jun 16, 2009 | 05:11 PM
I replaced everything you listed but I didn't do comp test yet. When I unplug each injector 1-4 the only one that doesn't choke the motor was number 2. I replaced the injector but didn't do nothing still. What else can it be?
rpc08
Sep 29, 2007 02:22 PM
sk8
Nov 17, 2004 02:54 PM
EK_vzla
Aug 30, 2004 01:39 PM
reVVin
Mar 31, 2002 07:03 PM
