engine management
Old Feb 20, 2007 | 12:27 AM
VTEC_PRODUCTION's Avatar
Default engine management
im looking into an ECU for my ride and im having a hard time with it...i plan on boosting and i want to get the most out of my tune...i do not know if i should get the stand alone or the piggy back or what...
i have picked out 3 different types of EMS or ECU and i would like to know which is the best...
The Greddy E-manage ultimate
AEM plug n play ECU
Microtech ltx-8
please if you can steer me in the proper direction...thank you for the help...
Old Feb 20, 2007 | 12:30 AM
Dunc's Avatar
BCICAN
Default Re: engine management (Acura_Integra_Type_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_Integra_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">im looking into an ECU for my ride and im having a hard time with it...i plan on boosting and i want to get the most out of my tune...i do not know if i should get the stand alone or the piggy back or what...
AEM plug n play ECU
Microtech ltx-8
please if you can steer me in the proper direction...thank you for the help...</TD></TR></TABLE>
Of those three listed, without a doubt I would choose the AEM. Have you also looked into other possible systems such as Neptune or the Hondata S300 unit? Those will be far less expensive than the AEM and get the job done well for you.
Old Feb 20, 2007 | 12:32 AM
kynetik's Avatar
Default Re: engine management (Dunc)
I think you can't go wrong with the AEM, Neptune or Crome Pro. But go with what your tuner prefers
Old Feb 20, 2007 | 04:08 PM
Default Re: engine management (kynetik)
ive been lookin at greddy's e-manage but can you tell me why crome pro or the s200 or even the s300? what are the pros and cons or the differences between them...ive looked around and read up on them but they just are too general...i would like to know what makes one better than the other or what is best to get the most power? i just dont know...
Old Feb 20, 2007 | 04:30 PM
vinai's Avatar
I believe that there is a great write up on some the tuning programs on TI.
Old Feb 20, 2007 | 04:36 PM
vinai's Avatar
Default Re: engine management (vinai)
Hehe found it sorry I should have just posted it straight away. I'm just not that good with TI's search function. http://www.team-integra.net/se...=1135
Old Feb 20, 2007 | 05:42 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_Integra_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">ive been lookin at greddy's e-manage but can you tell me why crome pro or the s200 or even the s300? what are the pros and cons or the differences between them...ive looked around and read up on them but they just are too general...i would like to know what makes one better than the other or what is best to get the most power? i just dont know...</TD></TR></TABLE>
If you had to do a food chain of tuning programs from worst to best, it would look something like:
- FMU $
- VAFC $
- E-Manage $$
- S200 $$$
- Neptune, Crome Pro, S300 $$$$
- AEM $$$$$$
- Motec $$$$$$$$
- Autronics $$$$$$$$$$$$$$$$$$$$$$$$$ haha
Basically if you were to choose between the S200 or S300, then definitely do the S300. It's all the little features that add up to making it much nicer i.e. boost controls, fuel compensation tables, USB connection, etc.
AEM is probably overkill since the other programs do a good job. I have never used Crome Pro or Neptune but I hear good things about it. I've used both the S200 and S300...and the S300 is hands down better and worth the little bit extra. All the programs from the S200 on will/should yield the same power for you. As long as you can control the fuel and ignition timing then the power is mainly up to your tuner and the parts you have.
Old Feb 21, 2007 | 06:02 PM
mrbgartner's Avatar
One option you might want to consider (a cheaper alternative) is sending your stock ecu to JET. Ive used their stuff before and really liked them. They can litterally do anything you want to do. You send them your specific specs on your motor, and they customize your ecu to match your motor. Id also put on a piggyback fuel controller just in case you want to turn up the boost later.
Old Feb 21, 2007 | 09:00 PM
doood's Avatar
been there done that
Default Re: engine management (mrbgartner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbgartner &raquo;</TD></TR><TR><TD CLASS="quote">One option you might want to consider (a cheaper alternative) is sending your stock ecu to JET. Ive used their stuff before and really liked them. They can litterally do anything you want to do. You send them your specific specs on your motor, and they customize your ecu to match your motor. Id also put on a piggyback fuel controller just in case you want to turn up the boost later. </TD></TR></TABLE>
thats a worse option than a vafc
Old Feb 25, 2007 | 09:25 PM
vinai's Avatar
Default Re: engine management (doood)
Read the freaking article I posted, it will answer most if not all of your major concerns. As a side not going "cheaper" on your tune is probably not a great idea.
xd69
May 13, 2005 04:15 PM
turbo craig
May 28, 2004 06:33 AM
gsr2jdm
Dec 18, 2003 11:23 AM
GSRdriver
Sep 14, 2001 01:55 PM
Tstorm
Aug 2, 2001 11:04 AM
