Ecu problems
How can you tell if a Ecu is shot?
Putting car back together and i'm pretty sure that ecu is not getting any power...
car will not start nor will afc go on
sorry if i did not search..
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr2jdm »</TD></TR><TR><TD CLASS="quote">How can you tell if a Ecu is shot?
sorry if i did not search..</TD></TR></TABLE>
Borrow an ECU from a friend. Plug it in, and see if it works.
or
Plug the ECU in to someone elses car.
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 »</TD></TR><TR><TD CLASS="quote">
or
Plug the ECU in to someone elses car.</TD></TR></TABLE>
ditto.....truely the only way to tell........also, you can pop off the cover of the ecu..do a visual inspection to see if anything is burnt/fried,etc..but testing it on a buddy's car would be ideal
or
ok
1) I check all fuses last night they were all fine
2) I also checked ECU in friends car and worked fine
Question is my srs is disconected but the is a plug from the fuse box that goes to the steering wheel...
is there anything that i'm not finding
i had a 95 integra but that was totaled so i switched everything to another 95 shell.
basically everything was swithed over.. deleted my srs and cruise control.
i checked volatage and power goes all the way passed the relay box but somewhere from the plug to the ECU theres a problem
Toda Party
Oct 9, 2001 10:56 PM
