engine light w. vtec, need help.
Old Jan 31, 2005 | 05:05 PM
halozero's Avatar
Default engine light w. vtec, need help.
hi, i searched and couldn't find anything so i find myself here.
i'm somewhat new to all of this so excuse me if i sound stupid.
i have a 94 rs w. a b16a sir ii swap, whenever i get around the 4/5k rpm range you here the vtec pop i believe and then soon after an engine light comes on. i'm running a p30 ecu which i'm told is obd1 and i'm not sure how to check it. my friend suggested a stick a paper clip in the open circuit where the green/brown wire is then turn the car 2 clicks and the engine light should blick with the code, however the engine light only comes on and goes off as normal if i'm doing it correctly as i believe i am.
any advice?
thanks in advance.
Old Jan 31, 2005 | 08:25 PM
b-power's Avatar
Default Re: engine light w. vtec, need help. (halozero)
im gonna take a shot in the dark and say either vtec oil pressure sensor or O2 sensor.
Old Feb 1, 2005 | 01:20 AM
halozero's Avatar
Default Re: engine light w. vtec, need help. (b-power)
are either of those costly to fix? i'm on a tight budget as of right now..
suno
Jan 27, 2008 06:36 AM
chuniepatuni
10
Dec 4, 2006 11:07 PM
T"u"Rtle
20
Feb 14, 2006 10:17 PM
lsvtecdude
Aug 13, 2005 05:24 PM
grlstockb18c1
Nov 3, 2004 07:07 PM
