engine gettin hot!
Old Dec 16, 2002 | 12:15 PM
94ls's Avatar
Default engine gettin hot!
what up playas? yo someone help me out. my teg is runnin kinda hot at idle. usually the needle is below half but when im just idling its right at half...this kinda worries me. i also dont have dick for heat in my car. the ac works great of course, but being that its winter and its only 30 degrees and ****..this ******* sucks! anyone that can help me out, i'd appreciate it! thanks, peace
Old Dec 16, 2002 | 12:41 PM
kamdog's Avatar
Default Re: engine gettin hot! (94ls)
check your coolent level, mine was low and it started to over heat and the heat was cold, so I filled her up and it works great.
Old Dec 16, 2002 | 12:46 PM
B2FiNiTY's Avatar
Check your coolant.
Old Dec 16, 2002 | 02:57 PM
MattG's Avatar
New User
Low coolant, air in the system, or maybe also a bad thermo sensor for the fan motor or a bad fan motor (but if the fan is not working you should still have heat).
Hopefully its just low coolant.
Old Dec 16, 2002 | 03:02 PM
AWDxBOOST's Avatar
Default Re: engine gettin hot! (MattG)
probably coolant....or the fan like someone said. Both are easy to check
Old Dec 16, 2002 | 04:42 PM
JICsube's Avatar
Default Re: engine gettin hot! (ls_teg)
is'nt the engine always hotter at idle???? come on playas
Old Dec 17, 2002 | 04:57 AM
94ls's Avatar
Default Re: engine gettin hot! (kamdog)
to all who replied! thanks fellas...appreciate it... my coolant level was def low...droppin some in lata! thanks again!!!! peace
mda56
Feb 19, 2011 01:44 PM
hondaboi7
Mar 12, 2009 07:49 AM
opg5009
Jun 11, 2007 08:40 AM
mike3
May 8, 2007 03:36 PM
Integra Integra
Dec 15, 2005 06:15 AM
