engine code 80? PLEASE HELP
my car just threw a CEl earlier ...started running like hell. idle sn't solid and feels like the car keeps bogging.
i check my CEL and i believe its reading code 80. it bllinks steady 8 times...but on the last blink it turns off really quick. am i reading it wrong and its a 71?
i looked up the code and it says "80 Exhaust Gas Recirculation insufficient flow detected "
does anyone know what is causing this and how it could be fix? this is upsetting since its my first CEL
ANY HELP WITH BE MUCH APPRECIATED!
Basically anything wrong with cylinder 1 could cause this problem. Does the car run poorly at all RPM or just a particular RPM?
Quick list (possibly incomplete) of things to check.
Distributor cap
#1 plug wire
#1 plug
#1 fuel injector (harness and the actual injector)
#1 valve adjustment
Compression test
Distributor cap
#1 plug wire
#1 plug
#1 valve adjustment
Compression test
