engine code 80? PLEASE HELP
Old Feb 12, 2008 | 10:08 PM
superdat1's Avatar
Default engine code 80? PLEASE HELP
my car just threw a CEl earlier ...started running like hell. idle sn't solid and feels like the car keeps bogging.
i check my CEL and i believe its reading code 80. it bllinks steady 8 times...but on the last blink it turns off really quick. am i reading it wrong and its a 71?
i looked up the code and it says "80 Exhaust Gas Recirculation insufficient flow detected "
does anyone know what is causing this and how it could be fix? this is upsetting since its my first CEL ANY HELP WITH BE MUCH APPRECIATED!
Old Feb 12, 2008 | 10:23 PM
superdat1's Avatar
so i did some research and i guess tegs dont have EGRs so it cants be an 80. so i looked up 71 and it said "random misfire cylinder 1" OBDII btw.
Old Feb 12, 2008 | 10:33 PM
yc_dc4mar's Avatar
its 71 and yes random misfire in cyl 1. been there.haha still there actually
Old Feb 12, 2008 | 10:47 PM
superdat1's Avatar
**** sucks!!! someone has to have had this happen to them before.
Old Feb 13, 2008 | 06:17 AM
d3vilishSi's Avatar
Default Re: (superdat1)
Have you checked wires, plugs, cap, etc.?
Old Feb 16, 2008 | 10:29 PM
slowassgsr's Avatar
I agree, check plugs, distributor connector and wires also. I once had the connector wire go bad and caused the engine to missfire and run like shet.
Old Feb 17, 2008 | 04:09 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: engine code 80? PLEASE HELP (superdat1)
Basically anything wrong with cylinder 1 could cause this problem. Does the car run poorly at all RPM or just a particular RPM?
Quick list (possibly incomplete) of things to check.
Distributor cap
#1 plug wire
#1 plug
#1 fuel injector (harness and the actual injector)
#1 valve adjustment
Compression test
Darkane
Jun 18, 2008 07:21 AM
h22acclude
Oct 13, 2003 11:31 PM
AamirCWITR
Jun 25, 2003 01:47 PM
ActiveAero
Jan 18, 2002 11:14 PM
