ECU help
Old Feb 10, 2005 | 08:21 AM
CbGirlSi's Avatar
Default ECU help
have a 01 gsr
will there be any problems with me running a 00 si ecu?
Old Feb 10, 2005 | 08:26 AM
boosted k20's Avatar
Default Re: ECU help (CbGirlSi)
i dont think so
Old Feb 10, 2005 | 08:40 AM
virusiidx's Avatar
i'm pretty sure the fuel maps are different, i dont think you would want to risk it.
Old Feb 10, 2005 | 08:43 AM
accord-lude's Avatar
y would you want to do that. ?
Default Re: ECU help (accord-lude)
the fuel and timing maps shouldt be that much different.
Old Feb 10, 2005 | 08:46 AM
virusiidx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-lude &raquo;</TD></TR><TR><TD CLASS="quote">y would you want to do that. ?</TD></TR></TABLE>
yeah btw, why are you thinking about putting in an si ecu?
Old Feb 12, 2005 | 03:17 AM
CbGirlSi's Avatar
Default Re: ECU help (virusiidx)
si ecu being the cheapest obd2b ecu i have access to
Old Feb 12, 2005 | 05:46 AM
DontBlink's Avatar
the si ecu wont open your secondaries(more than likely you'll get a check engine light from this), vtec engagement will be in a different spot(rpm wise). fuel maps could be different, if you have to do this id put a wideband on the car to make sure your not running super lean somewhere. and i also belive(someone correct me if im worng) the si ecu has an immobilizer in it, so with out the key that matches that computer the car wont start.
what do you need a different computer for?
typeRSi
Oct 11, 2005 02:47 PM
808b18c1boosted
Jan 11, 2004 08:59 AM
sinatra
Dec 25, 2003 04:18 PM
turbod16y8
Dec 16, 2002 02:20 PM
