what ecu is this?
Old Oct 9, 2005 | 04:40 PM
typeRSi's Avatar
Default what ecu is this?
the numbers are 37520p2ta11 and 1170122270 and Z4? any help would be great im new to these cars.
Old Oct 9, 2005 | 06:11 PM
slomofo's Avatar
GDD Member
99-00 Civic Si
Old Oct 9, 2005 | 06:35 PM
typeRSi's Avatar
Default Re: what ecu is this? (typeRSi)
what is the ecu number for a b18c5? thanks for the help
Old Oct 9, 2005 | 06:48 PM
TurboEM1's Avatar
37520p2ta11
thats how you know its for a 99 - 00 si.
heres for future reference
Old Oct 9, 2005 | 09:42 PM
typeRSi's Avatar
ok i just got this car its a 00 si with a b18c5 normal bolt ons but the ecu is a factory Si ecu it runs and drives great but i know it should have alot more power when i test drove it it was fast but when i got it home i noticed that the pass kick panel was half off and the ecu was just sitting there so i think the guy i bought it from took out the right ecu and put the factory Si ecu back in.
what ecu should i get to get the best out of this motor.
Old Oct 10, 2005 | 12:19 PM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeRSi &raquo;</TD></TR><TR><TD CLASS="quote">ok i just got this car its a 00 si with a b18c5 normal bolt ons but the ecu is a factory Si ecu it runs and drives great but i know it should have alot more power when i test drove it it was fast but when i got it home i noticed that the pass kick panel was half off and the ecu was just sitting there so i think the guy i bought it from took out the right ecu and put the factory Si ecu back in.
what ecu should i get to get the best out of this motor. </TD></TR></TABLE>
why dont you try an OBDII GSR ECU, since it would make sense to use the ECU that goes with the engine. or you could convert to obd1 and use any number of chippable OBD1 ECUs and tune as needed.
Old Oct 10, 2005 | 12:59 PM
slomofo's Avatar
GDD Member
Default Re: what ecu is this? (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">
why dont you try an OBDII GSR ECU, since it would make sense to use the ECU that goes with the engine. or you could convert to obd1 and use any number of chippable OBD1 ECUs and tune as needed.</TD></TR></TABLE>
Because the OBDII GSR ECU isn't the ECU that goes with the B18C5 motor.
ITR ECU = P73
GSR ECU = P72
Old Oct 10, 2005 | 08:13 PM
nsracingcivic99's Avatar
just run a obd2b-obd1 jumper harness and get a chipped out gsr computer for it... a p72 ecu
Old Oct 11, 2005 | 06:28 AM
drdisco69's Avatar
Default Re: (nsracingcivic99)
I wouldn't even bother finding a P72, the intake runner butterfly control will just have to be disabled anyway. Find a P28, chip it and tune it, and be done.
Old Oct 11, 2005 | 02:47 PM
typeRSi's Avatar
thanks for all the help. ill prob end up getting a p72. i think after that im gonna sell it if your interested let me know.
99fbpem1
Aug 6, 2007 09:05 AM
SIguy626
Jul 30, 2006 09:06 PM
sinatra
Dec 25, 2003 04:18 PM
sshaikh01
Feb 28, 2003 11:00 PM
