Check ECU code 41
Old Mar 6, 2003 | 12:48 PM
BlackB18CTeg's Avatar
Default Check ECU code 41
I checked my engine codes, and it turned out to be 41. The O2 sensor. THe acura dealer told me that it was because I had a CAI on my car. I doubt that this is true. Anyone know what to do? I considered buying a new one, but it is 230, and not really worth it unles I have to.......
Old Mar 7, 2003 | 08:52 AM
LsPower's Avatar
Default Re: Check ECU code 41 (BlackB18CTeg)
My car did this too. There is another thread on this too called sensor 41. It should help a little more.
Old Mar 7, 2003 | 12:20 PM
JimBlake's Avatar
Yeah - check the other thread. DTC#41 is for the preheater circuit for the O2 sensor. It has NOTHING to do with your CAI. Unless you tore some wiring loose when you installed it...
Old Mar 7, 2003 | 12:24 PM
VTEC-DA's Avatar
Default Re: Check ECU code 41 (JimBlake)
What other mods do you have? The only time I ever got a 41 was when I had my test pipe.
Old Mar 7, 2003 | 01:12 PM
JimBlake's Avatar
Default Re: Check ECU code 41 (VTEC-DA)
Knowing what code 41 is about, I'd be surprised if ANY mods could be responsible. It's just a heater circuit. You could take your O2 sensor out, plug it back into the wire, & duct-tape it to the underside of the car. It would throw code #1 for a bogus oxygen measurement, but you'd have to cut some wires or blow a fuse to get #41. Of course, if the heater inside the sensor is toasted that'll do it...
dusterbd13
Oct 20, 2009 01:15 PM
AccordEX1991
Aug 6, 2007 02:49 PM
vtec25
Mar 14, 2006 02:39 AM
YaMaJeSty
Jul 26, 2002 04:01 AM
ITR#97-0039
Jan 16, 2002 02:51 PM
