distributor problem
Old Jun 21, 2009 | 07:41 AM
yzhang's Avatar
Default distributor problem
I need help, bro. my car won't start up, everything is normal the day before it happend. i changed a new battery, still the same. engine does crank, but does not fire up. is this a distributor problem?? and how do i make sure its the distributor gone bad?? thanks
Old Jun 21, 2009 | 08:08 AM
ek-g6's Avatar
Default Re: distributor problem
you can go to autozone or kragen n get the ignition coil tested n the control module tested. You can take out the spark plug wire from the engine n put a spark plug in it and have a friend crank the engine while you check for spark. Are getting fuel? Another cause could be a bad main relay.
Old Jun 21, 2009 | 08:16 AM
yzhang's Avatar
i filled up the car couple days ago, plus, i smell gasoline after i crank it couple times. if i want to test the spark, do i have to place the spark plug somewhere to have it spark?? connect ground wire or something??
Old Jun 21, 2009 | 08:19 AM
ek-g6's Avatar
I just left it near a valve cover bolt and had my friend crank the car while I check out side for spark.
Old Jun 21, 2009 | 09:12 AM
yzhang's Avatar
if its a main relay problem, the spark plug still spark, right??
Old Jun 21, 2009 | 09:27 AM
lobudgetr's Avatar
My experience with main relays is that usually the check engine light wont come on when you first start up and then go off. I think that you don't get fuel pressure either though.
Old Jun 21, 2009 | 11:13 AM
94 ls-r's Avatar
The main relay controls most of the car. If it is bad you will have no spark or fuel. Sounds like it gettin fuel tho cause you can smell it. I would test the dizzy
DelSlowmo
61
Feb 12, 2009 07:50 PM
GoldCoin
Aug 21, 2006 06:29 PM
94_civic_dx
May 18, 2005 08:57 PM
EGB18
11
Oct 1, 2004 04:24 PM
gLotex70
May 31, 2003 01:30 AM
