differculty in installing a distributor?
Old Jul 1, 2005 | 02:46 PM
LoseRPunKx182's Avatar
Default differculty in installing a distributor?
my distributor finally came in and i was just wondering how hard it is to install it by myself? my buddy's a mechanic so i was suppose to go down to his place but it's a friday nite and i dont want him missin a friday...but i want it in cause my dizzy's shot
Old Jul 1, 2005 | 03:03 PM
blkb18's Avatar
Default Re: differculty in installing a distributor? (LoseRPunKx182)
its very easy as long as you have a timing light and know how to set your timing.
Old Jul 1, 2005 | 03:05 PM
Default Re: differculty in installing a distributor? (blkb18)
no timing light...maybe i should wait for my friend for backup
Old Jul 1, 2005 | 03:12 PM
Jeezer's Avatar
its plug and play, then you just make shure the timing bolt is right in the middle. but if you never done it its kinda hard. it only take 5 minutes or less so dont worry just let your friend do it
Old Jul 1, 2005 | 03:16 PM
MickeeFREE's Avatar
it isnt as hard as spelling difficulty... hahahah i kid i kid
Old Jul 1, 2005 | 03:32 PM
Default Re: (MickeeAgain)
comp sci major
i've read others just making tick marks so it lines up the timing?
Old Jul 1, 2005 | 03:36 PM
damn...timing guns are expensive. what's the timing suppose to be btw
Old Jul 1, 2005 | 04:17 PM
IN VTEC's Avatar
Default Re: (LoseRPunKx182)
Marking lines might not cut it since you'd have to transfer the lines to the new distributor. It's too precise to allow that much error. But, if you're gonna do it, err to the side of a little too much timing.
You should be able to rent a timing gun from Autozone. Full priced deposit, full refund when you return it. Just don't shoot yourself in the eye with it.
Base ignition timing is 16 deg BTDC.
Old Jul 1, 2005 | 04:26 PM
MickeeFREE's Avatar
Default Re: (IN VTEC)
marking soewaht help.... u can rent timing gun.. at ur local automotive store...
well atleast the ones that has the tool loaning program....
Old Jul 1, 2005 | 05:39 PM
ernald711's Avatar
as stated easy
Old Jul 1, 2005 | 06:56 PM
Default Re: (ernald711)
thanks for the info guys ...i ended up fixing an idling problem so i didn't get around to it tho
Old Jul 1, 2005 | 07:05 PM
Contender25
Guest
Posts: n/a
If you have a screwdriver, a flathead, and can remember where pieces/spots are, and can pop in and out things, via the rotor, distributor, the spark plug wires. Easy stuff mang, if you got a prob just post back, ill let you know.
Old Jul 1, 2005 | 07:18 PM
yeah it seems easy enough...screw here screw there...but w/o the timing gun i rather not mess with it yet. that doesn't mean u wont hear from me tho haha
Old Jul 1, 2005 | 08:05 PM
FormulaGSR's Avatar
just advance it all the way you'll be fine
Old Jul 1, 2005 | 08:07 PM
Arsenal's Avatar
You don't need a timing gun. Take the three bolts off, and mark where they were origanally positioned. Pull the distributor out, mark the rotor.
Put the new one in. it will only go in one way with the camshaft, thus the timing is not greatly affected so long as the lines and marks face each other.
i did one about 1 week ago, and had the timing checked before and after and both were exactly the same.
Took about 10 mins to do.
Old Jul 1, 2005 | 08:27 PM
Contender25
Guest
Posts: n/a
Yeah forgot to mention that, i already marked mine with a black marker.
Old Jul 1, 2005 | 08:51 PM
that's kinda where i got confused...if u mark it with the old dizzy in...how would u know where to line up when u put the new distributor in
Old Jul 1, 2005 | 11:46 PM
88redrex's Avatar
Just don't strip those damn bolts....I did it. Flame me.
Old Jul 2, 2005 | 10:11 AM
mpham529's Avatar
Default Re: differculty in installing a distributor? (88redrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88redrex &raquo;</TD></TR><TR><TD CLASS="quote">Just don't strip those damn bolts....I did it. Flame me.</TD></TR></TABLE>
i did too me
Old Jul 2, 2005 | 02:36 PM
which bolts
Old Jul 2, 2005 | 03:13 PM
quick question..i know ur suppose to clip the timing gun on the spark plug wire # 1...but i forget which is # 1 lol
Old Jul 2, 2005 | 05:29 PM
FormulaGSR's Avatar
on any engine number 1 is the one closest to the crank pulley.
Old Jul 16, 2005 | 07:15 AM
Bonez21's Avatar
Default Re: (FormulaGSR)
are you ****** serious????????
Timing gun? you don't need no stinking timing gun!!!!
Three bolts bitch and it comes off then put then new one on, that simple, 3 bolts again and the top bolt (facing the bottom end of the hood) is where you set the timing. Put that bolt closest to the middle as you can DONE wtf its like pullin teeth
Old Jul 16, 2005 | 10:55 AM
allmotorteg_96's Avatar
Default Re: (Bonez21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonez21 &raquo;</TD></TR><TR><TD CLASS="quote">are you ****** serious????????
Three bolts bitch and it comes off then put then new one on, that simple, 3 bolts again and the top bolt (facing the bottom end of the hood) is where you set the timing. Put that bolt closest to the middle as you can DONE wtf its like pullin teeth</TD></TR></TABLE>
if you follow these directions closely your timming will be profecto.
Old Jul 16, 2005 | 08:09 PM
Arsenal's Avatar
Default Re: (allmotorteg_96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 &raquo;</TD></TR><TR><TD CLASS="quote">if you follow these directions closely your timming will be profecto.</TD></TR></TABLE>
Which has already been stated 10 times and needlessly brought up again.
