Difference between obd1 ls and obd2 ?
Old Aug 23, 2005 | 01:14 AM
nevin's Avatar
Default Difference between obd1 ls and obd2 ?
I have a motor (b18b) and dont know what year it is.
Old Aug 23, 2005 | 02:00 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: Difference between obd1 ls and obd2 ? (nevin)
Your motor debuted in 1994 and was used through 2001. If it was either 1994 or 1995, it would be an OBD1, anything after 1995 is OBD2. As far as the ECU is concerned, there were two varients OBD2A & OBD2B which indicates whether or not your ECU was equipped with an immobilizer.
I think:
1996 - 1999 (OBD2A) = no immobilizer
2000 - 2001 (OBD2B) = immobilizer present
I drive a 1999 GSR and I don't have that green light on the cluster that shows my car is equipped with an immobilizer.
Old Aug 23, 2005 | 06:24 AM
klungemonger's Avatar
The quick way to tell by looking at the actual motor is check at the crank pulley to see if there is a harness/plug coming out from under the timing cover...if so then it is OBD2, if not it's OBD1. That is the crank fluctuation sensor found on all OBD2 Hondas.
Old Aug 23, 2005 | 07:07 AM
xteg95's Avatar
the year is also in your VIN
Old Aug 23, 2005 | 08:12 AM
PLAGUED_DB7's Avatar
Default Re: Difference between obd1 ls and obd2 ? (xteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 &raquo;</TD></TR><TR><TD CLASS="quote">the year is also in your VIN </TD></TR></TABLE>
He has the motor only rocket scientist.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger &raquo;</TD></TR><TR><TD CLASS="quote">The quick way to tell by looking at the actual motor is check at the crank pulley to see if there is a harness/plug coming out from under the timing cover...if so then it is OBD2, if not it's OBD1. That is the crank fluctuation sensor found on all OBD2 Hondas.</TD></TR></TABLE>
X2
Old Aug 23, 2005 | 08:15 AM
94IntegraLs04's Avatar
Default Re: Difference between obd1 ls and obd2 ? (PLAGUED_DB7)
96-01 obd-2 b18b 94 95 b18b is obd-1
Old Aug 23, 2005 | 09:16 AM
nevin's Avatar
cool thanks guys
Old Aug 23, 2005 | 09:23 AM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">
X2</TD></TR></TABLE>
umm motors (blocks) have the VIN stamped on them fellow genuis.
Old Aug 23, 2005 | 11:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 &raquo;</TD></TR><TR><TD CLASS="quote">umm motors (blocks) have the VIN stamped on them fellow genuis.</TD></TR></TABLE>
But if he doesn't know how to interpret the VIN it doesn't help him...seriously, he didn't know the difference between the OBD's...
Old Aug 23, 2005 | 11:44 AM
xteg95's Avatar
Default Re: Difference between obd1 ls and obd2 ? (klungemonger)
But if he doesn't know how to interpret the VIN it doesn't help him...seriously, he didn't know the difference between the OBD's...</TD></TR></TABLE>
I think looking at a VIN and looking for a series of numbers that end in 94,95,96, ect is easier that figuring out the difference between OBD's to some
wowy978
Engine Management and Tuning
Oct 7, 2008 11:05 AM
92integraVTECgsr
Jun 1, 2008 04:30 PM
strictly.business
Nov 25, 2006 09:05 PM
b20_ed
Nov 10, 2005 12:25 PM
92civic_si
16
May 6, 2004 02:50 PM
