converting an obd1 motor to obd2, for the 5th time, what has to be changed!
Old Nov 24, 2006 | 08:14 PM
strictly.business's Avatar
Banned
Default converting an obd1 motor to obd2, for the 5th time, what has to be changed!
what has to be changed on and obd1 b16a so it wont throw codes with and obd2 ecu?
thanks.
Old Nov 25, 2006 | 12:21 AM
Banned
up.
Old Nov 25, 2006 | 12:52 AM
njn63's Avatar
obd2 conversion harness.
secondary o2 sensor.
Old Nov 25, 2006 | 05:56 AM
civicstar's Avatar
Default Re: (njn63)
what about the crank position sensor? hmm wouldnt it just be easier to do obd1 still? but whatever you like.
well just put it in and see wat codes it throws from there
Old Nov 25, 2006 | 11:13 AM
Banned
lmao.
my car is obd2. i need to know what needs to be changed/swapped on the motor for the obd2 ecu not to throw codes.
Old Nov 25, 2006 | 07:06 PM
civicstar's Avatar
Default Re: (strictly.business)
most people still convert their obd2 car to OBD1 to make it easier, its hard to make an obd1 motor work with obd2 ecu without codes, like the crank position sensor, obd1 motors dont have that so i dont know how ur gonna bypass that. usually what most people do is just get an obd1 ecu, and adapter harness from obd2 to obd1, no need to change out injectors or distrib, all u need is just the harness and ECU
good luck,
Old Nov 25, 2006 | 07:27 PM
Banned
im not ******* dumb. the car is already running an obd1 ecu. i have to convert the motor to obd2 so i can run an obd2 ecu to pass emissions. the crank position sensor is in the oil pump on obd2 motors. im just gunna jump the two wires together to fool the ecu.
i need to know what else needs to be changed.
and civicstar, please dont post in my threads anymore.
Old Nov 25, 2006 | 08:47 PM
civicstar's Avatar
like u said what needs to be done and ur not dumb, so put it in and read the codes, and live and learn buddy. trial and error only u can do that for yourself
Old Nov 25, 2006 | 09:05 PM
Banned
Default Re: (civicstar)
CAN YOU NOT ******* READ? stop posting in my threads, your information is useless.
up for some info.
emooheo
Mar 13, 2010 12:37 PM
topherchris
Sep 26, 2007 07:30 PM
92civic_si
16
May 6, 2004 02:50 PM
1man
Jul 21, 2003 11:45 AM
hatchy
Mar 31, 2002 08:24 AM
