DA Speaker question...
Old May 7, 2004 | 01:21 PM
chwmeinthg's Avatar
Default DA Speaker question...
Does anyone know the front speaker sizes for DA chassis integras? Also where i could get the rear speaker enclosure things and a dash kit for the receiver? The car's system was jacked from the guy that had the car before me. Thanks.
Old May 7, 2004 | 01:23 PM
g2homboi's Avatar
Default Re: DA Speaker question... (chwmeinthg)
i think they are 6.5" speakers..
Old May 7, 2004 | 01:40 PM
LOWNSLOW's Avatar
aren't they 5 1/4?
Old May 7, 2004 | 02:04 PM
..::91TEG-G2::..'s Avatar
Default Re: DA Speaker question... (2Slow2Run)
6.5, i have a set.. there 6.5 all the way around
Old May 7, 2004 | 02:22 PM
dannylDAsport's Avatar
Default Re: DA Speaker question... (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">6.5, i have a set.. there 6.5 all the way around</TD></TR></TABLE>
Old May 7, 2004 | 05:07 PM
ansay's Avatar
http://www.crutchfield.com/cgi...eid=0
jus put in the info and the rite speaker sizes and deck code comes out.
i ordered from here before and i know that for my deck they threw in a dash kit...if what your talkin about is the spacer that the new reciever will fit into. dont know what you mean about rear speaker inclosers...but if your talkin about speaker boxes you can get a few there too...but you can also make em.
hope that helps
any car audio shop should carry the dash kit and speaker boxes
Old May 7, 2004 | 05:11 PM
RidinStock's Avatar
Default Re: DA Speaker question... (ansay)
Yea, this is right, I installed four Polk DB650's at 6 1/2" on my DA. Good luck on getting a new deck, you might as well go aftermarket though (my system's on the stock deck... and that sucked to wire). As for a box, don't worry about it, get four good 6 12" and it will sound fine IMO.
Old May 7, 2004 | 05:16 PM
N-tegra's Avatar
Default Re: DA Speaker question... (RidinStock)
I have a DA and My speakers are 5.25 all the way around...
RidinStock's Avatar
Default Re: DA Speaker question... (N-tegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N-tegra &raquo;</TD></TR><TR><TD CLASS="quote">I have a DA and My speakers are 5.25 all the way around...</TD></TR></TABLE>
What year? If it is year specific, mine is a 93... which means they maybe grouped the years 90-91 and 92-93? Hm... bump for info.
Old May 7, 2004 | 05:25 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ansay &raquo;</TD></TR><TR><TD CLASS="quote">http://www.crutchfield.com/cgi...eid=0
hope that helps
any car audio shop should carry the dash kit and speaker boxes</TD></TR></TABLE>
Old May 7, 2004 | 05:33 PM
riceball777's Avatar
front is 5 1/4 and rear is 6 1/2
Old May 7, 2004 | 06:07 PM
Colin's Avatar
everyone is right.... both 6.5's and 5.25's fit. Just depends on the exact speaker. Just about any 5.25" should fit, and many 6.5's will fit but many will be too deep for the front (you can remedy this by cutting the back of the basket they mount to, or remove the basket and make your own spacer).
I personally am running 6.5's all the way around. Getting the fronts to fit was some work since I'm using CDT Audio cl61's which are really deep. I would personally recommend 6.5's over 5.25's. Usually the cost isn't much more for the larger speakers and getting them to fit isn't much of a problem... if any problem at all. So in most cases I don't see a significant reason to opt for the smaller speaker.
Old May 8, 2004 | 06:08 AM
Xsi's Avatar
Xsi
I would suggest making your own spacer out of 18mm MDF anyway, your speakers will sound better
Old May 8, 2004 | 10:25 AM
aznballer's Avatar
i had 6 1.2 in my 91 and 93 there is no diff
Old May 8, 2004 | 11:42 AM
IMMORTAL-B18's Avatar
6 1/2" will fit in the front. you might need a spacer or whatever that makes it to where they can bilt in. I have an MB Quart component set that are 6 1\2". Some say 6X9 will fit in the back with modification, but I threw some infinity 6 1\2" back there as well.
Old May 8, 2004 | 11:57 AM
mr.beeks's Avatar
6.5 in the front but you will have to do some cutting
unless you get some beyma speakers.....
in the back 6.5 with no mods...........
Old May 8, 2004 | 12:00 PM
Speed_Dreams's Avatar
My 90 has 6.5 all the way around
Old May 8, 2004 | 06:26 PM
Default Re: (Speed_Dreams)
ya there is 2 different sizes you can fit.. if you look closly.. u can see 2 different mounting holes, but dont get it confused with the screws that hold on the factory style box on there.
Old May 8, 2004 | 07:11 PM
Honda Hick's Avatar
You're best bet for the plastic pieces is to hit a junkyard. You could probably pick up all the pieces you need for $15.
redline870
Acura TSX
Nov 21, 2008 05:55 AM
Silver Surfer
Audio / Security / Video
Jul 13, 2006 09:44 PM
97jdmdc2gsr
May 10, 2006 04:19 PM
Mike1486
Jan 1, 2005 11:25 PM
Whitegsr2000
Sep 28, 2004 11:13 PM
