Speaker Size Question
Old Dec 31, 2004 | 05:50 PM
Mike1486's Avatar
Default Speaker Size Question
For x-mas I got a set of Pioneer 5 1/4 inch speakers. Will they fit even though my old speakers are 6 inches?
Old Dec 31, 2004 | 08:46 PM
svtec's Avatar
L D E S
Default Re: Speaker Size Question (Mike1486)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike1486 &raquo;</TD></TR><TR><TD CLASS="quote">For x-mas I got a set of Pioneer 5 1/4 inch speakers. Will they fit even though my old speakers are 6 inches?</TD></TR></TABLE>
just pull the panel off and try. my friends nissan takes both sizes in the front doors, so i imagine with a little bit of retrofitting they wil work.
Old Dec 31, 2004 | 08:47 PM
thaiphob's Avatar
Nikon!!!
Default Re: Speaker Size Question (svtec)
the fronts are 6.5's
Old Dec 31, 2004 | 08:49 PM
svtec's Avatar
L D E S
Default Re: Speaker Size Question (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">the fronts are 6.5's</TD></TR></TABLE>
as well as the rears, but the depth for the speakers in the rear is shallow, so i modified mine by cutting out the plastic cage so the magnet could go through it.
with a little bit of ingenuity anything can be possible with those speakers.
Old Dec 31, 2004 | 11:29 PM
TunerN00b's Avatar
Crutchfield used to sell 6 1/2 to 5 1/4 adapters, and I've seen them at audio stores as well. Though, honestly, you have space for 6 1/2 in the front, might as well see if you can return those and get bigger speakers. You'll get much better low end out of a 6 1/2 than a 5 1/4. Even with a 10" or so in the trunk, you still want the fronts to go as low as possible to avoid a gap in the frequency range.
If you can't find adapters, you can use a sheet of platic, thin plywood, styrafoam, or anything else that will hold them in place. Cut the material in the shape of the exiting speaker, and mount it in there as a stock speaker, and cut a hole in the middle, and bottom mount the new speaker behind that. If you need a better explaination, message me and I'll answer when I'm less drunk.
I had to cut out the back of the plastic speaker mount in the door, and add some foam (weather protection) http://www.crutchfield.com/S-n...7XT65 behind it, to mount my Infinity's, since they are so deep (physically), but the improvement over stock is completely worth it.
You can also use those foam baffles and replace the existing plastic holder with wood, styrafoam, or anything else, and just cut it to the size you need.
Before anyone questions the use of styrafoam, go check how the rear speakers of a G3 coupe are mounted.
Old Jan 1, 2005 | 04:57 AM
EnjoyTheRideDC2's Avatar
Default Re: Speaker Size Question (TunerN00b)
5.25's will screw into the OEM baskets, they just wont match up to the holes pre drilled for a 6.5. I also advise you to pick up a decent pair of 6.5 if you can exchange those you received.
If there is no other option but to use the speakers you got, slip the speaker into the speaker basket and find locations you can screw the speaker down to the basket.
Old Jan 1, 2005 | 11:25 PM
calxtreme's Avatar
they'll fit, but i think the new speakers probably also come with an adapter.
Paul*DC4
Audio / Security / Video
Mar 19, 2008 07:44 PM
Djole_V
Oct 30, 2006 06:32 PM
hungpham214
10
Oct 20, 2006 05:59 PM
D_CRX_Si
Dec 23, 2005 03:29 AM
VizjereiAvatar
Aug 6, 2004 08:46 PM
