components, coaxials, speakers, explain.
Old May 8, 2006 | 08:36 PM
97jdmdc2gsr's Avatar
Default components, coaxials, speakers, explain.
Hey I did some searching but came up empty...Audio isnt exactly my thing but I'm trying to get more knowledgeable in it....
My question is, whats the difference between a component speaker and a regular speaker? also whats a coaxial speaker? what is the purpose of a cross over?
If anyone has any links, please feel free to send them my way...thanks.
Old May 9, 2006 | 08:27 AM
B18C_EJ8's Avatar
http://www.google.com/search?hl=en&q=car+audio+faq
Old May 9, 2006 | 01:35 PM
Skip01's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.google.com/search?hl=en&q=car+audio+faq</TD></TR></TABLE>
haha,at first i thought that said Car+ Audio+ ***....woulda been funny.
Old May 9, 2006 | 04:21 PM
midoublez's Avatar
Default Re: components, coaxials, speakers, explain. (97jdmdc2gsr)
alright a component set usually consists of a high range and a mid range speaker. the mid is usually the frequency from a stock speaker, with less bass. the bass is the low frequency that makes your ears pulse. the high makes you waht to cover your ears. comp sets can have crossovers built in or seperate. the crossover filters out the certain frequency to the correct speaker, example the high pass only allows high range to go through crossing out the mid and bass, mid blocks the bass and high, and bass blocks high and mid range frequencies. a coaxial speaker is both a mid and high range. it looks like a speaker giving a little one a piggyback ride, this is also an example of a cross over that is built in the high has its own filter to block all but high frequencies. ok i hope i explained enough
Old May 9, 2006 | 04:29 PM
EBP_SI's Avatar
Default Re: components, coaxials, speakers, explain. (midoublez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midoublez &raquo;</TD></TR><TR><TD CLASS="quote">alright a component set usually consists of a high range and a mid range speaker. the mid is usually the frequency from a stock speaker, with less bass. the bass is the low frequency that makes your ears pulse. the high makes you waht to cover your ears. comp sets can have crossovers built in or seperate. the crossover filters out the certain frequency to the correct speaker, example the high pass only allows high range to go through crossing out the mid and bass, mid blocks the bass and high, and bass blocks high and mid range frequencies. a coaxial speaker is both a mid and high range. it looks like a speaker giving a little one a piggyback ride, this is also an example of a cross over that is built in the high has its own filter to block all but high frequencies. ok i hope i explained enough</TD></TR></TABLE>
i couldnt come up with a less coherant explanation if i tried
Old May 9, 2006 | 08:11 PM
Default Re: components, coaxials, speakers, explain. (EBP_SI)
wow very good explanation thanks...
Old May 10, 2006 | 04:19 PM
midoublez's Avatar
what chu talkin bout willis
midoublez's Avatar
no problem
OneFire
Audio / Security / Video
11
Nov 3, 2008 12:56 PM
standbackimapro
16
Mar 14, 2007 10:18 AM
mrdeadman
12
Jan 2, 2006 05:51 PM
Whitegsr2000
Sep 28, 2004 11:13 PM
pezzy
Sep 5, 2004 08:47 PM
