CTR vs ITR
Old Oct 26, 2003 | 05:41 PM
thrty8street's Avatar
Default CTR vs ITR
Civic type R cams versus Integra type r cams, what are the pros and cons to each?
why is it that many people swap CTR cams into their integras instead of ITR cams? whats the reasoning behind this? What are the price differences?
Old Oct 26, 2003 | 05:47 PM
VTECorona's Avatar
Default Re: CTR vs ITR (thrty8street)
I'm pretty sure the exhaust cam is the same for all years. The intake cam on 00-01 ITR is the same as CTR. Before 00-01, ITR's intake cam was slightly less aggressive than the CTR intake cam. This has been discussed alot, try a search
Old Oct 26, 2003 | 06:07 PM
patdemps's Avatar
Default Re: CTR vs ITR (VTECorona)
ITR cams are sold quite a bit cheaper. ITR cams 00-01 are the same exact camshaft as the CTR cams. The years before as stated above were just <U>slightly</U> less aggressive. not something to get your panty's all in a bunch about. i dont understand why people pay more for CTR cams. The extra they cost you should look into getting some skunk2 cams, etc. I say ITR camshafts are the best bang for a buck.
Old Oct 26, 2003 | 08:43 PM
VTECorona's Avatar
Default Re: CTR vs ITR (patdemps)
How much can a set be had for? New vs. Used.
Old Oct 26, 2003 | 10:07 PM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECorona &raquo;</TD></TR><TR><TD CLASS="quote">How much can a set be had for? New vs. Used.</TD></TR></TABLE>
arm vs. leg
Old Oct 26, 2003 | 10:38 PM
M-Type's Avatar
CTR 310-350 each
ITR 270-300 each
varies from desperate seller vs greddy seller
Old Oct 26, 2003 | 11:00 PM
sohc it to me's Avatar
Default Re: CTR vs ITR (M-Type)
u can find 00-01 itr for alot cheaper then ctr, when i parted out my old motor i sold my 01 itr cams for 250
Old Oct 27, 2003 | 04:07 AM
thanks for all the replies
Old Oct 27, 2003 | 04:12 AM
lMlElNaCe-GSR2's Avatar
Default Re: (thrty8street)
no problem
Old Oct 27, 2003 | 06:59 AM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M-Type &raquo;</TD></TR><TR><TD CLASS="quote">
CTR 310-350 each
ITR 270-300 each
varies from desperate seller vs greddy seller</TD></TR></TABLE>
That's a lot of dough for OEM cams. I'll probably end up going with skunks since they are 600ish for a set.
Old Oct 27, 2003 | 07:44 AM
BlackSage's Avatar
What the hell does greddy have to do with OEM cams?
I would look into buying a pair of 97-98 ITR camshafts. Sure they are not as agrressive but there is not change in HP or dynos ( that I have seen) for the 97-98 vs 00-01 ITR.
lo0nY
30
Mar 11, 2004 12:20 AM
JDMlyfestyle
Nov 1, 2003 06:26 PM
AllMoToRB18c
Oct 26, 2003 02:33 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
-Darren-
Apr 8, 2002 11:58 AM
