Could it be?
Old Jan 27, 2009 | 06:32 PM
LSxVQ35's Avatar
Default Could it be?
So yeah it was pretty embarassing earlier in front of the traffic. I was ready to make a left. Light turned green and i get on the clutch but my shifter wouldn't go to 1st gear. It took me 5 tries to get onto 1st gear. This was so embarassing as it was the 1st time it happened to me. Could this be my transmission? I have a new shift linkage and bushings and a brand new clutch so its none of those.
Old Jan 27, 2009 | 08:04 PM
slick91's Avatar
Default Re: Could it be?
are u sure its not the clutch this happened to me a while back ....does it go into gear when the car is off???
Old Jan 27, 2009 | 08:10 PM
Jimmy's Avatar
Global Moderator
How about a better topic title? How about more info? What year? what model? no one can help you with no info.
Old Jan 27, 2009 | 08:23 PM
superacecardriver's Avatar
check your fluid level would be first thing to check. Maybe even change it, if it has not been done in awhile.
Old Jan 27, 2009 | 08:43 PM
g3Gsr443's Avatar
**** happens dont flip your wig.
Old Jan 27, 2009 | 11:32 PM
scbmx87's Avatar
Sounds like you're low on tranny fluid. Flush it and fill it up.
Old Jan 28, 2009 | 04:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If it has a new clutch then it should have fresh fluid. However if the OP filled the fluid with only the front end lifted on jack stands, then that will give a false full reading and will actually be too low.
Old Jan 28, 2009 | 07:11 AM
HONDRETTI's Avatar
so, for those of us who don't have a lift, what is the best method for topping off your tranny case?
Old Jan 28, 2009 | 07:18 AM
WinningNinja's Avatar
I used a funnel with a "straw". You can buy them at autozone this way. I had a buddy feed me the straw and I stuck it into the the hole and lowered the jack. Pretty simple.
Old Jan 28, 2009 | 03:05 PM
StokelesS_g2's Avatar
You could always fill it up from your VSS area also. (remove VSS)
It'll be alot easier with that straw funnel.
Also always re-adjust your clutch pedal after changing the clutch.
You can easily warp your clutch disc and flywheel if it's not in spec.
Old Jan 29, 2009 | 09:11 AM
TIMMY4TOES's Avatar
cable, hydro what year, are you using super thick gear oil, syn?
Old Jan 29, 2009 | 09:35 AM
Community Builder
Use 4 jack stands or fill it thru the VSS hole w/ the car sitting on the ground (I use the VSS hole regardless).
The first time I changed my clutch years ago and filled the tranny with only the front end in the air, I realized what I had done. When I topped it off with the car level, almost another 1/2 quart went into the case before starting to drip out the filler hole.
Old Jan 29, 2009 | 10:15 AM
Shawn C's Avatar
In The Garage
haha, damn... i just use one of those funnels w/ the ~2ft flexible hose. i remove the intake, i pull the trans fill plug, bend the hose into the hole, and its easy could be.
to the OP, i'suggest visually inspecting the linkage. make sure that the bitch pin (spring pin that connects the linkage to the trans, theres a bolt/nut on one linkage bar, and the bitch pin in the other bar). make sure that pin is there, and not just a loose bolt or somethin. also, possibly the bolt going through the linkage at the bottom of the shifter is too tight or something. or could be low clutch fluid or air in the line (i don't know if any of this was disconnected when the clutch job was done. either way, i'd take it to whoever just worked on the clutch fo sho maybe use gm synchromesh fluid in the tranny. just go to any gm/chevy dealer and ask for 3 qts of part # 12345349. it'll be about 13 bucks a quart, but its the only good thing gm ever did
Old Jan 29, 2009 | 10:26 AM
Jimmy's Avatar
Global Moderator
hahaha.. heard that! lately i've been going to autozone and picking up the pennzoil synchromesh and it works great also.. it's also only 8 bucks a quart
niceprelude
Nov 7, 2008 10:22 AM
DC5Danny
Jan 21, 2008 08:36 AM
01_S2k_Driver
Feb 7, 2005 04:23 AM
Toretto
May 12, 2003 01:02 PM
jteasy
Oct 30, 2001 07:12 PM
