Need advice
Re: Need advice (niceprelude)
look on the firewall next to the brake fluid...i believe. im not 100% sure. and if its not your tranny fluid or clutch fluid then yes...probably you will.
your clutch is bad when the pedal is almost all of the way out and the clutch engages. Also if its slipping when in gear. If in gear the RPM's jump when you mash the gas but the car doesnt go its slipping.
