Coolant everywhere..blown headgasket?
Old 08-26-2010, 06:48 PM
liquidx's Avatar
Default Coolant everywhere..blown headgasket?
So I have a 99 teggy and i had a small leak right next to the radiator hose and inlet. I just have been refilling my coolant. I havent driven it very much, so today i drove it came home and there is coolant spilling out it seems like from the block......under where the radiator hose is and right around where the headers connect to the block.........is this a blown headgasket? if it is could it have been a small leak that turned into a blown headgasket or was this a blown headgasket the whole time?
Old 08-26-2010, 07:02 PM
mouab18c1's Avatar
Default Re: Coolant everywhere..blown headgasket?
Its something external. Blown headgasket would not have coolant flying out everywere like how you stated.
Old 08-26-2010, 07:27 PM
liquidx's Avatar
well let me check my oil to see if its milky and I will get and replace the radiator hose.....any other ideas?
Old 08-26-2010, 07:31 PM
1998GsRIntegra's Avatar
Coolant drain bolt on the block is loose? I doubt it though. Might be worth checking.
Old 08-26-2010, 08:22 PM
Drive 4 fun's Avatar
Sometimes a leak from a hose or from the radiator itself will spray back ontothe motor. Leaks are commom from the plastic/metal seam on to of the radiator. Mine sprayed everything. Wash it down and then start it up and look. You should be able to see a leak like you are describing, especially once it is hot.
Old 08-27-2010, 10:22 AM
liquidx's Avatar
well i'll let it cool and pull it into my garage and run it...i'm going to refill the coolant....the leak was only from the hoses before and if its a new leak from the radiator it would suck......so going to get rid of this car lol
Old 08-27-2010, 10:55 AM
mouab18c1's Avatar
Coolant lines or radiators are all easy fixes.
Jimi Hondrix
03-05-2017 05:21 PM
crxaddikt
03-25-2014 11:00 PM
raju687
09-16-2011 05:42 PM
honda_coupe
01-24-2006 03:10 PM
Jeffrey9
11-16-2005 10:31 AM
Quick Reply: Coolant everywhere..blown headgasket?
