Coolant Disappearing
Old 12-27-2007, 08:38 AM
da_33's Avatar
Default Coolant Disappearing
So I been noticing that my reservoir always seems to be low on coolant so I fill it up and it disappear and the rad always seems full. But now that we have snow on the ground when i move the car I notice a spot where it looks like its dripping from but I don't know where that would be. The rad is full but the reservoir goes low? Any ideas
Old 12-27-2007, 08:40 AM
pdotjones's Avatar
Default Re: Coolant Disappearing (da_33)
maybe a tiny hole in the resevoir... i would get a rag, wipe all the hoses clean, an dinspect for leaks.... you should be able to trace where the leak is coming from...
Old 12-27-2007, 10:08 AM
* B A N N E D *
St Jimmy's Avatar
Yea sounds like a leak in the resivor somewhere. If you had a leak in the coolant lines somewhere they would likely steam and be really noticeable so i'm betting its in the resivor somewhere or along the line that goes to the top of the radiator.
Old 12-27-2007, 12:47 PM
da_33's Avatar
well i have an idea where it drips down bc u can see it in the snow but the car is to low to even put your head under to look and i dont have anything to really raise it up, ill try wiping down the lines and see if anything seems to drip or get wet while its running
SeanK325
06-22-2010 02:52 PM
anduhy
11-19-2007 11:44 PM
Evolution-93-Ex
11
07-02-2006 11:31 PM
DC2point0
15
03-22-2006 12:05 AM
deechiguy
03-04-2005 08:53 AM
Quick Reply: Coolant Disappearing
