did a compression test today.......
Old Feb 29, 2004 | 09:22 PM
QuanKwan's Avatar
Default all you CTR Pistons owner in a B18C5, help with compression #s plz!!! desperate!
I did a compression test today, the day was sweet so i was out working on the car... and the results... which I am still confused by... any input would be great.
I just got my car back from the shop, with CTR standard bore pistons, in a B18C5, and did a compression test to make sure the motor was running good.
Results and the Order from 1-4... 239, 240, 239, 240.
My question is, even tho the motor is good and dandy the fact that they are very consistant and close to each other, doesn't it seem low for CTR pistons? I believe CTR pistons bumps from the factory 10.6 to 12.1-12.3 approx.
From what I was told it was suppose to be close to 300 all around.
Correct me if im wrong or for asking such stupid questions, but any help would be great.
thanks
Modified by QuanKwan at 2:56 AM 3/2/2004
Old Feb 29, 2004 | 09:33 PM
B2FiNiTY's Avatar
Default Re: did a compression test today....... (QuanKwan)
Different compression testers show different compression numbers. As long as they are all close you are good to go.
Old Feb 29, 2004 | 10:07 PM
Syner-G-Racing LLC's Avatar
if your not happy with the results try dumping a teaspoon of oil into each spark plug well and see if that gives you the numbers you want. if so change you piston rings and youll be good to go. those readings were good though, practically anything above 200psi is really good. if the pressure doesnt jump after adding oil then you may want to look into replaceing your valve guides and possibly your retainers. make sure you do the test properly...all of the spark plugs out and the throttle wide open ( i use lock wire and wrap it around my butterfly and tie off at the intake)
Old Mar 1, 2004 | 12:15 AM
JDM TypeR 307's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuanKwan &raquo;</TD></TR><TR><TD CLASS="quote">I did a compression test today, the day was sweet so i was out working on the car... and the results... which I am still confused by... any input would be great.
thanks </TD></TR></TABLE>
Did you have to completely rebuild your motor?
Old Mar 1, 2004 | 06:30 AM
QuanKwan's Avatar
I Just swapped out pistons
Old Mar 1, 2004 | 08:22 AM
SlapSmak's Avatar
those reading sound more accurate for JDM Type R pistons which yield 11.1:1 with a stock head gasket and 11.3:1 with a spoon or mugen 2 ply gasket.
Old Mar 1, 2004 | 09:48 AM
jr_istheman's Avatar
Default Re: did a compression test today....... (SlapSmak)
sounds a tad low for 11.8 comp but your readings are very consistent, which is the most important.
glad to see you rebuilt your engine with the TODA belt this time, no more timing belt snaps good luck with your dyno tuning homie
Old Mar 1, 2004 | 12:31 PM
D's Avatar
D
Default Re: did a compression test today....... (Syner-G-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">if the pressure doesnt jump after adding oil then you may want to look into replaceing your valve guides and possibly your retainers. </TD></TR></TABLE>
wow... thats a brilliant comment... from the president of Syner-G-Racing yo.
D
Old Mar 1, 2004 | 12:57 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: did a compression test today....... (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">
D
LMFAO!!!!
Old Mar 1, 2004 | 05:51 PM
QuanKwan's Avatar
ahhh anyone with CTR pistons in their B18C5 can tell me what the compression #s should be?
DC_Legacy
Jan 20, 2011 10:46 AM
GSR in Progress
Jan 10, 2006 06:37 PM
Robs_B18c
22
Oct 6, 2005 06:05 PM
BDBGoalie1982
Sep 5, 2004 08:58 AM
92slowvic
May 29, 2003 09:29 PM
