A simple question
Old Aug 25, 2004 | 09:00 PM
Sport_Injected's Avatar
Default A simple question
if you do a compression test and a leak down test on a motor, and the results all came out normal, would that rule out any chance of scratches in the cylinders or worn valve seals?
i guess what im asking is, if you had scratches in your cylinders or your valves werent sealing properly, would you be able to tell from the compression and leakdown test results?
Old Aug 25, 2004 | 09:18 PM
dunkd's Avatar
yes. but sometimes the problems may be so small the tests wont discover them yet...
Old Aug 25, 2004 | 09:21 PM
AutoWerks's Avatar
Default Re: A simple question (Sport_Injected)
no...
vavles seals can be determine from startups in the morning and it smokes alot.
scratches on cyllinder wall could only be looked at to determine if it leaks.
leakdown only determines if rings are bad or vavles bent or not seated..
compression is basily the same
97integraa
Apr 16, 2015 11:25 PM
Vladglad
20
Dec 18, 2013 02:56 PM
humboldt_skim
May 31, 2008 08:18 AM
EF8_SiR
Jul 20, 2003 10:24 PM
Propulsion
Jun 5, 2002 11:48 PM
