Compression Test Results!
Old Mar 26, 2009 | 05:45 AM
94_Teggy's Avatar
Default Compression Test Results!
Ok so i got bored and decided to do a compression test.
Engine:b18c
Cylinder 1- 220
Cylinder 2-217-219(gauge was just under 220)
Cylinder 3-220
Cylinder 4-220
What do you guys think about those results?Good or bad?
Old Mar 26, 2009 | 06:00 AM
sirmugenpower's Avatar
Default Re: Compression Test Results!
pretty damn good
Old Mar 26, 2009 | 06:56 AM
94_Teggy's Avatar
i was told the engine had about 40k on it..its really clean an runs perfect...just looked at the engine and its from 1993!!
Old Mar 26, 2009 | 07:19 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
a 93 gsr in a 94 teg?
Did you do the test with normal engine temp?
Old Mar 26, 2009 | 08:19 AM
94_Teggy's Avatar
yup..drove it to the auto part store to pick up the tool then drove bak and did it!!
yeh a 93..i was told to look at the first circle mark on the head...it says 9/3
Old Mar 26, 2009 | 10:24 AM
1992db2's Avatar
yea, those numbers are good. How many times did you crank it?
Old Mar 26, 2009 | 10:54 AM
Bteggy's Avatar
did you do a full throttle compression test?
Old Mar 26, 2009 | 12:50 PM
94_Teggy's Avatar
no..should i do a full throttle one?i cranked it about 4 times
Old Mar 26, 2009 | 03:02 PM
95dc2teg's Avatar
It came out of a 94 gsr but it was assembled in 93.
Old Mar 26, 2009 | 05:15 PM
Bteggy's Avatar
yeah you should do it. also crank it about 8 times
Vladglad
Oct 20, 2016 07:20 PM
gtec8285
Jun 24, 2008 01:18 AM
92siracer
Jun 2, 2004 10:29 PM
Vanilla4215
Nov 7, 2002 09:46 PM
joeg26er
Feb 6, 2002 08:27 AM
