did a compression test
Old Nov 7, 2002 | 02:44 PM
Vanilla4215's Avatar
Default did a compression test
I did a compression test and got:
cylinder 1:200
cylinder 2:200
cylinder 3:192
cylinder 4:192
This was with the engine cold. Should I worry about anything?
Old Nov 7, 2002 | 02:53 PM
Norcalstoppy's Avatar
Default Re: did a compression test (Vanilla4215)
what engine is that for?
Jay Kim
Old Nov 7, 2002 | 03:28 PM
tinkerbell's Avatar
Default Re: did a compression test (AllMotorMonster)
looks like it could be a healthy B16A?
how do you get such accurate numbers? digital readout gauge or what?
t..
Old Nov 7, 2002 | 03:30 PM
Chiovnidca's Avatar
cylinder 1:200
cylinder 2:200
cylinder 3:192
cylinder 4:192
A compression test should be done on a warm engine to get accurate results.
Old Nov 7, 2002 | 03:33 PM
tinkerbell's Avatar
Default Re: did a compression test (Chiovnidca)
cylinder 1:200
cylinder 2:200
cylinder 3:192
cylinder 4:192
with the throttle open and injectors switched off...
PS why did you do a compression test?
t..
Old Nov 7, 2002 | 03:41 PM
Chiovnidca's Avatar
Default Re: did a compression test (tinkerbell)
Make sure the ignition is disabled, so the coil doesn't fry.
Old Nov 7, 2002 | 03:45 PM
tinkerbell's Avatar
(you may also have some codes to clear at the end of the test...)
t..
/ends thread hijack/
Old Nov 7, 2002 | 09:46 PM
kinesistech's Avatar
[QUOTE]how do you get such accurate numbers? digital readout gauge or what?
QUOTE]
My snap-on tester has hash marks for the one's place. On my leak down tester the second gauge is divided by tens and given percentages, I just replaced the gauge with one that reads 0-100 with hash marks the get the same accuracy there.
02BladeRider
Jul 7, 2017 05:49 AM
Powered by VTEC
Feb 3, 2008 08:36 PM
silverEH2
Oct 14, 2003 11:54 AM
Chubz
Dec 22, 2002 12:31 PM
Chubz
Jun 27, 2002 02:00 PM
