1991 Acura integera compression test
Old Oct 12, 2016 | 02:50 PM
Vladglad's Avatar
Default 1991 Acura integera compression test
did a dry compression test numbers came out 170 across all cylinders. Does this mean the motor is healthy ?
Old Oct 13, 2016 | 11:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: 1991 Acura integera compression test
Your saying all four cylinders are at 170, I find that hard to believe, around 170 maybe, but all at exactly 170 no
Was this test done on a warm engine?
Was test done with more then a couple cranks of engine for each cylinder?
Was it done with TB at WOT?
If all the above is yes, then you have a healthy engine standard compression is 184, minimum is 135, but the main thing is no more then a 28psi difference between any cylinder, so with all of them at 170psi I would say it is healthy. 94
Old Oct 20, 2016 | 08:00 AM
Tarmac Junkie's Avatar
170 psi is well within spec for that engine.
John
Old Oct 20, 2016 | 07:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
Could still be healthy from the comp numbers but doesnt mean it dont consume oil ect but the numbers show a consistant even amount so the rings are good.
76 camaro car
Apr 20, 2017 04:47 AM
Belarus
Apr 2, 2010 03:01 AM
guero2craze
May 8, 2007 09:15 PM
John.
Jun 12, 2006 08:45 AM
Jordan_4WS
Apr 23, 2002 02:58 PM
