compression test
Old Mar 10, 2004 | 10:11 PM
ITR77's Avatar
Default compression test
Honda dealership did my compression test and Its 195 psi on all four cylinder. Is this good or bad. This is low or what? Thanks for the help.
Old Mar 11, 2004 | 06:12 AM
tonykart59's Avatar
Default Re: compression test (01ITR0716)
from reading other posts on this site, i beleive that is average.
the search button is your friend
Old Mar 11, 2004 | 09:16 AM
genetsang's Avatar
a tad bit low.... as long as its consistant all the way across. you should be good for now.
Old Mar 11, 2004 | 09:57 AM
FlaN.'s Avatar
yea, that's a little low for an ITR. my '95 RS had the same numbers..
Old Mar 11, 2004 | 02:18 PM
danteisme's Avatar
Loved
Community Favorite
Default Re: (theJUMPoff)
my gsr had 225 damn near the whole way across, dunno how that should compare to an ITR tho
Old Mar 12, 2004 | 04:58 AM
JimBlake's Avatar
Default Re: (danteisme)
Before we all go comparing actual pressures, remember that ALL of this stuff has to be the same...
1) Same gauge. The internal volume of the gauge/hose matters. So does the location of the check valve inside the gauge.
2) Same rpm when the starter cranks. Oil temperature & battery condition & a handfull of other things influence this. For example, if you only remove one sparkplug at a time, it'll crank more slowly.
3) Same throttle position. Wide-open.
4) Same cranking procedure. I prefer cranking until the pressure quits rising, not counting how many revolutions...
nevrkno
Dec 8, 2008 06:08 PM
Tad
Jun 27, 2005 12:04 AM
AgentJam
Nov 20, 2004 07:17 PM
cu3tip
Mar 14, 2004 09:03 PM
Petah
Aug 19, 2003 11:37 PM
