code 17 help!!!
Old Jul 30, 2011 | 07:22 PM
98tegLSvtec's Avatar
Default code 17 help!!!
so i got a code 17 on my 98 integra, was wondering where the ssv is located and what all could cause it thanks
Old Jul 31, 2011 | 12:38 PM
mouab18c1's Avatar
Default Re: code 17 help!!!
ECU CODES (Thanks to Drag III Integra)
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
67 Catalyst low efficiency. (same as P0420)
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
Its your VSS not ssv. It's mounted on your transmission.
Old Jul 31, 2011 | 01:33 PM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/vss.html
91ef8sir
20
Jan 29, 2013 11:24 AM
redef90si
Aug 29, 2011 05:09 AM
93b20z
May 18, 2009 04:59 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
SwapGOD
Mar 25, 2002 06:17 PM
