need help with a code 91 Integra.....
Old Aug 26, 2011 | 10:24 PM
redef90si's Avatar
Default need help with a code 91 Integra.....
3 solid flashes, 3 quick ones only happens when I drive in high altitudes.Any help would be greatly appreciated,Thanks;Matt.
Old Aug 26, 2011 | 10:32 PM
mouab18c1's Avatar
Default Re: need help with a code 91 Integra.....
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
67 Catalyst low efficiency. (same as P0420)
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
Code 3 and code 30?
Old Aug 26, 2011 | 10:54 PM
redef90si's Avatar
it's a 5spd weird? So it looks like she needs a new Map sensor that's Ntb
Old Aug 26, 2011 | 10:58 PM
redef90si's Avatar
Thanks man,I had a feeling it was the MAP sensor but confirmation is great.
Old Aug 27, 2011 | 08:34 AM
mouab18c1's Avatar
Your car is a 5 speed? What ecu do you have?
Old Aug 27, 2011 | 09:22 PM
redef90si's Avatar
obdo pr4 5spd
Old Aug 28, 2011 | 07:11 PM
BoltonGSR's Avatar
I had that code when I did a B20 swap on my integra with a P75 ECU.
After much research I found this link,
http://www.ff-squad.com/technet/code91.htm
Old Aug 29, 2011 | 05:09 AM
redef90si's Avatar
Thanks for your help man
91ef8sir
20
Jan 29, 2013 11:24 AM
98tegLSvtec
Jul 31, 2011 01:33 PM
Laz's EP
22
Feb 22, 2010 12:09 AM
DA_Boy_626
Oct 3, 2007 06:50 PM
xxthabest1xx
Mar 15, 2003 06:06 PM
