Cluster doesnt light up after installing a headunit
Old May 14, 2005 | 05:17 PM
dungsta's Avatar
Default Cluster doesnt light up after installing a headunit
I have a 97 integra and i recently had a new head unit put in and evey since the the gauge cluster's back light wont come on .. i kno the light isnt messed up because when i turn the alarm on and off it still blinks... i've checked the fuses seeem like nuttin is blown..
can someone help me out thanks.. i cant drive at night!!
thanks..
Old May 15, 2005 | 11:29 AM
dannylDAsport's Avatar
Default Re: Cluster doesnt light up after installing a headunit (dungsta)
get a wiring diagram and recheck the wires, u might have connected ur illumination wire wrong somewhere behind the headunit
Old May 15, 2005 | 12:10 PM
Ehop's Avatar
also check ur fuses
Old May 15, 2005 | 01:56 PM
dungsta's Avatar
Default Re: (Ehop)
i've checked my fuses seem like it still doesnt work..
Old May 16, 2005 | 06:36 PM
Default Re: Cluster doesnt light up after installing a headunit (dannylDAsport)
disconnect the headunit and see if it fixes ur problem.
Old May 16, 2005 | 06:56 PM
Big Bang's Avatar
did you use a adapter harness or did you hard wire it? If you did the latter i'd almost gaurante that you hooked the radio ground up to the dimmer wire
Old May 17, 2005 | 01:43 PM
dungsta's Avatar
Default Re: Cluster doesnt light up after installing a headunit (The Converted)
fix the problem and it was the fuses
thanks h-t
Rand The Man
Aug 23, 2012 10:08 AM
UnleashedEJ1
Jan 31, 2011 01:36 PM
dungsta
May 16, 2005 01:57 PM
dungsta
Audio / Security / Video
May 16, 2005 01:56 PM
dungsta
May 15, 2005 01:57 PM
