Cluster doesnt light on after installing a headunit
Old May 14, 2005 | 05:16 PM
dungsta's Avatar
Default Cluster doesnt light on after installing a headunit
I have a 97 itr and i recently had a new head unit put in and evey since the the gauge cluster's back light wont come on .. i kno the light isnt messed up because when i turn the alarm on and off it still blinks... i've checked the fuses seeem like nuttin is blown..
can someone help me out thanks.. i cant drive at night!!
thanks..
Old May 15, 2005 | 01:58 PM
dungsta's Avatar
Default Re: Cluster doesnt light on after installing a headunit (dungsta)
someone help?
Old May 15, 2005 | 04:27 PM
audioroach's Avatar
did you short out a fuse?...did you use the illumination wire for the
new radios ground instaed of TRUE ground? I say recheck your install
it may be something really simple.
Old May 15, 2005 | 06:20 PM
dungsta's Avatar
Default Re: Cluster doesnt light on after installing a headunit (audioroach)
yeh i re checked everything still hav a problem wit it
Old May 15, 2005 | 07:51 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 itr and i recently had a new head unit put in and evey since the the gauge cluster's back light wont come on .. i kno the light isnt messed up because when i turn the alarm on and off it still blinks... i've checked the fuses seeem like nuttin is blown..
thanks..</TD></TR></TABLE>You have blown the dash light fuse, [probably because the radio illumination wire was shorted or miswired when the new HU was installed] the reason they blink when you arm/disarm the alarm is, the alarm supplies the power, you need to find the blown fuse, and the the short, [if it's still there] before you do damage to the alarm, [the lightflash output can be damaged]. 94
Old May 16, 2005 | 01:56 PM
dungsta's Avatar
Default Re: Cluster doesnt light on after installing a headunit (fcm)
thanks it works noww
integramic
May 29, 2005 09:07 AM
dungsta
May 17, 2005 01:43 PM
dungsta
May 15, 2005 01:57 PM
hypnotic
Sep 30, 2003 08:32 PM
