check engine light
Old Feb 19, 2015 | 03:10 PM
Randyb18's Avatar
Default check engine light
I need help guys how can I read my check engine codes. I have a 1994 integra and can't seem to find a place that has obd1 scanners !!! Please help
Old Feb 19, 2015 | 03:32 PM
B_Swapped93's Avatar
Default Re: check engine light
there is no such thing as a obd1 scanner you use a paper clip and jump the 4 pin connecter on the pass side, it's up by your glove box. it's the 2 bigges holes in the 4 pin.
Old Feb 19, 2015 | 03:52 PM
wunfstgsr's Avatar
Loved
Community Favorite
jump a paper clip in the plug and read the blinks of the check engine light on the dash. Google the obd1 code blinks.
Old Feb 19, 2015 | 03:56 PM
Randyb18's Avatar
The 2 pin plug ?
Old Feb 19, 2015 | 04:04 PM
Randyb18's Avatar
Nvm I read wrong
Old Feb 19, 2015 | 04:37 PM
Randyb18's Avatar
My check engine light only turns on when I'm driving will it still work ?
Old Feb 19, 2015 | 04:38 PM
turn the car to ignition 2 (II) then jump it.
Old Feb 19, 2015 | 04:41 PM
Randyb18's Avatar
The ignition is on and still nothing I am plugging the paperclip wrong or something ?
Old Feb 19, 2015 | 05:21 PM
yes you are make a shape and then put it in the 2 biggest holes. stop asking to be spoon fed and use google that's how the rest of use learned you're just being ignorant now. same deal as an integra
Old Feb 19, 2015 | 06:52 PM
Randyb18's Avatar
OK thanks
Old Feb 19, 2015 | 07:56 PM
slomofo's Avatar
GDD Member
Just because you've never heard of them, doesn't mean they don't exist.
There's two plugs over there under the glove box, one is for jumping and counting flashes, the other is for the OBD1 scanner. The scanner can pull codes, data log, clear codes, and various other functions.
Old Feb 19, 2015 | 09:28 PM
K20.ek's Avatar
Mine is the 2 pin plug to read the codes
lgoodgrace
Apr 27, 2015 03:43 PM
jdmsir4dr
Apr 4, 2010 12:04 AM
mafiasutra24
Oct 9, 2008 10:34 PM
hothondas
Aug 4, 2008 06:24 PM
Audipwr1
Jun 3, 2003 08:26 AM
