check engine light
My 95 gsr is throwing a check engine light. I jumped it with the plug on the passenger side to get the light to flash. The way it flashed I'm not to sure what it means. It went 2 regular flashes then 2 quick flashes, 2 regular flashes 3 quick flashes. I need help on knowing that these codes mean. It is a rebuilt motor with only 350 miles on it. The check engine light only comes on after a little bit of driving but goes back off when the car shuts off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 909dc2 »</TD></TR><TR><TD CLASS="quote">These are the ECU codes:
22 (VTEC pressure valve)
23 (Knock sensor) </TD></TR></TABLE>
That's already been established...
My knock sensor is broken so thats why its on. My vtec is working fine what could the problem be then? My gas mileage doesn't seem like its that good
Is there some kind of seal or something for that sensor? The check engine light seems to come on quicker when it has oil in the plug. Some times when I'm taking off and it hits vtec it sounds like its tapping out would that be caused by the bad sensor?
CrisEK
13
Jun 12, 2005 02:48 AM
