changing the tps
Old Jan 25, 2009 | 09:17 PM
googoodc's Avatar
Default changing the tps
hey guys, well i have been having some trouble with my 94 ls. i need to change my tps and when i was looking at it i noticed that there are no screw or bolt heads on what ever it is holding it to the tbody, if anyone has or knows how to change it please help
Old Jan 25, 2009 | 09:20 PM
superacecardriver's Avatar
Default Re: changing the tps
you can just break off the rivets and make your own adjustable tps. Finding the correct threaded screw or bolt.
Old Jan 25, 2009 | 09:37 PM
roc0487's Avatar
take a grinder and grind a slot across the rivets deep enough to fit a flat head screwdriver into, then take a hammer and tap the flathead further into the rivets and unscrew them. Find 2 bolts or screws with the same threads and reattach your new tps. Keep in mind that it will need adjusted with a multimeter. I'm unsure of the voltage though.
Old Jan 25, 2009 | 09:47 PM
racebum's Avatar
this is exactly what you do and you set the voltage at .50 v closed and 4.50v open.
Old Jan 25, 2009 | 09:53 PM
googoodc's Avatar
how do i adjust it?
Old Jan 25, 2009 | 10:19 PM
racebum's Avatar
Originally Posted by googoodc
how do i adjust it?
search, there is more than one write up on here
Old Jan 27, 2009 | 11:56 AM
roc0487's Avatar
you can see that the mounting points of the TPS itself aren't circles, they are more like a () so you can rotate the sensor until you get the correct voltage reading and snug the screws/bolts down. I wish I had a pic
thanks for the info on the adjustment bro, I was drawing a blank. lol
p3tey2
Honda S2000
Jun 19, 2011 01:41 AM
Evasion
Aug 20, 2010 05:37 PM
cehcivic15
Aug 14, 2009 01:56 AM
b18 hatch mike
Jun 11, 2007 04:25 PM
htownteg
Jan 24, 2004 08:48 AM
