CEL question
Old Jul 28, 2005 | 12:57 PM
Sic's Avatar
Sic
Default CEL question
i know you all prob get enough of these but when i drive for about 10-20 mins my CEL comes on. now im tryin to jump my ecu (in the faq) but still no blinking i think its been idle for 10 mins should i drive it around till the light comes on/blinks?
Old Jul 28, 2005 | 12:59 PM
Preferio's Avatar
Default Re: CEL question (Sic)
if the light has came on, then it will be saved... so, your light shout be on.. if there is a code... and it will flash to let you know that it's working..
Old Jul 28, 2005 | 01:05 PM
Sic's Avatar
Sic
Default Re: CEL question (95IntegraLSR)
mabye i got it hooked up wrong then but heres what i did. Is this the right green connector?(was drawn in mspaint in 5 secs)
Old Jul 28, 2005 | 01:08 PM
Preferio's Avatar
what year car do you have, and what is it? i'm assuming it's an obd1 integra
Sic's Avatar
Sic
95 rs. thing is that the auto tranny is off a 98 integra which is a obd2 think that would be throwing it?
Old Jul 28, 2005 | 01:10 PM
Preferio's Avatar
quite possibly...
but you're using the harness under the glove box right?
Old Jul 28, 2005 | 01:12 PM
Sic's Avatar
Sic
yah damn trial heh heres what i thoguht i should be plugging into dont mind the blue/silver speaker wire
http://img203.imageshack.us/im...v.jpg
*EDIT*
So i got the right green thing? i just pull jump the brown and black wires? Got any pics cause i dont wanna mess it up
*EDIT x 2*
Ok it worked ill get pics up if anyother person needs help code 17
Modified by Sic at 2:56 PM 7/28/2005
Modified by Sic at 3:02 PM 7/28/2005
Preferio's Avatar
the harness you need to be jumping is just a blue, two wire plug...
Old Jul 28, 2005 | 01:16 PM
Preferio's Avatar
it will have two wires going to it, ones black, and the other is brown with a white stripe... i'm guessing that you're a trial user and have used up all your posts.. see if you can go in and keep editing them... instead of posting anew reply....
Old Jul 28, 2005 | 01:24 PM
Preferio's Avatar
ok, pull the plug out on the right of the green casing.. its there for protection...
then on the female side of it, jump a wire... got it? from the black wire to the brown/white wire..
Old Jul 28, 2005 | 02:05 PM
Sic's Avatar
Sic
thanks man i got it i can post a pic up for ppl since i havent seen a picture. Code 17
4DALOOKS92
Apr 16, 2016 07:46 AM
moarlow95ex
Jan 16, 2014 04:00 PM
EJ6er
Jun 30, 2011 08:50 PM
bbrian
Aug 31, 2005 07:14 PM
TurboInteg95
Apr 13, 2002 07:02 PM
