CEL code retrieval
Old Apr 12, 2002 | 07:46 PM
TurboInteg95's Avatar
Default CEL code retrieval
can someone tell me how to pull the CEL codes from the compter?
Thanks
Old Apr 12, 2002 | 07:50 PM
SOHCArchangel's Avatar
Default Re: CEL code retrieval (TurboInteg95)
there should be a two port blue harness around the glove box, use a jumper wire or a paper clip and hook into both ports and turn the key to the accessories positionand watch for the blinking light
Old Apr 12, 2002 | 09:15 PM
Default Re: CEL code retrieval (SOHCArchangel)
OK, I'm retarded. On my Integra there is a 2 pin connector that I short to retrieve the codes, it is located by the passenger kick panel. I cannot find this damn connector on my girlfriends 98 Accord. Is it in the same place? the only thing I found was the 16 pin connector that the OBD2 scan tool hooks into. I have the list of OBD2 codes, I just needs to make that damn light blink.
Thanks
Brian
[Modified by TurboInteg95, 10:41 PM 4/12/2002]
Old Apr 12, 2002 | 09:40 PM
CmptchAV6's Avatar
You have to connect pins 8 and 13 on the data link connector under the drivers side dash. I tried to do an ASCII drawing of the diagram the 2 X's are the pins that you need to connect. After connecting these pins you need to turn the ignition to the on position without the engine running and watch the Check engine light and see how it flashes. Long Flashes are 10's places and short flashes are 1's places. I.E. 4 long flashes and 2 short flashes = the code 42. It will flash all engine codes that are in memory and then it will repeat them. Check them for accuracy and then come back on here and IM me on h-t or reply to this thread and I will look up the codes for you.
|__\
|_|_|
|_|_|_
|_|_| |
|_|_| |
|X|_| |
|_|_|_|
|_|_|
|_|X|
[Modified by CmptchAV6, 12:40 AM 4/13/2002]
[Modified by CmptchAV6, 12:41 AM 4/13/2002]
Old Apr 12, 2002 | 09:43 PM
Default Re: CEL code retrieval (CmptchAV6)
ah, ok, so there is no 2 pin connector that you short out. it is part of the datalink connector. cool, thanks. I have a list of OBD2 codes from an integra, they might be the same, I will post the codes I get anyway. Thanks
Brian
Old Apr 12, 2002 | 09:51 PM
ok, I could swear I was getting 2 codes, one was 67 and the other was 76. However, I dont have a listing for 76 in my OBD 2 integra manual, maybe there is a 76 for an accord or maybe not. The listing for 67 shows up as the secondary o2 sensor or catalytic converter.
Old Apr 13, 2002 | 03:06 AM
CmptchAV6's Avatar
76 is cylinder 6 misfire
67 is catalist system efficiency below threshold
I hope it is a V6 otherwise 76 could not be a possible code.
Old Apr 13, 2002 | 08:49 AM
hmm, misfire in cylinder 6. hehe, it's a 4 cylinder. I will check it again, probaby needs an 02 sensor.
Old Apr 13, 2002 | 09:25 AM
4doorH22's Avatar
|__\
|_|_|
|_|_|_
|_|_| |
|_|_| |
|X|_| |
|_|_|_|
|_|_|
|_|X|
Holy **** dude, did you type/draw that out yourself? You are the master.
Old Apr 13, 2002 | 07:02 PM
CmptchAV6's Avatar
Default Re: CEL code retrieval (4doorH22)
yeah I typed that out myself. It sux it looked better before I posted it as the bottom indention was lined up before I hit the post button. It wasnt really that hard tho.
76 camaro car
Aug 1, 2015 12:11 PM
Spithead051
Oct 20, 2013 07:05 PM
Visionist
Jul 13, 2003 10:53 AM
Ricey McRicerton
Jun 18, 2003 11:55 AM
BigChris
Apr 2, 2003 01:32 PM
