cel help...
Old Feb 24, 2004 | 11:37 AM
D_TY3's Avatar
Default cel help...
Hey guys I am in need of some help.
I have a cel 61, which refers to the primary O2 sensor.
I replaced the O2 sensor with a brand new Bosch O2 sensor
and I reset the ECU, but I am still getting the cel 61.
Can anyone shed any light on the subject.
Or another approach to fix the problem?
Thanks in advance
dennis
Old Feb 24, 2004 | 11:43 AM
Chris's Avatar
Default Re: cel help... (D_TY3)
any mods?
please explain the light sequence (shorts, longs)
Old Feb 25, 2004 | 04:05 AM
D_TY3's Avatar
Chris,
I put in a neuspeed header and rsr cat-back
The cel is six long, one short (61)
Modified by D_TY3 at 3:28 PM 2/25/2004
Old Feb 25, 2004 | 07:41 AM
Quiks66's Avatar
Your problem most likely has to do with the wiring. If you have any experience with it, try to follow the wires from the O2 sensor back up into the car as far as you can. Somehow one of the wires may have been tugged at when you installed the header, which could potentially keep the sensor from providing a reading and sending it back to the ECU. If you're not comfortable with looking at it, have someone who knows what they're doing (don't pay a shop if you don't have to) take a look at it. Hope that helped.
Old Feb 25, 2004 | 07:57 AM
D_TY3's Avatar
Default Re: cel help... (Quiks66)
thanks
will try to do this on the weekend
Old Feb 25, 2004 | 08:15 AM
SuzukaBlueAP2's Avatar
Just wanted to add....did you use the Bosch sensor that you have to wire ? If so, make sure you followed that correctly and the wires are in the right places.
Old Feb 25, 2004 | 08:17 AM
TurboedGSR's Avatar
rather than follow the wire, borrow a voltmeter
Old Feb 25, 2004 | 09:02 AM
D_TY3's Avatar
Default Re: cel help... (TurboedGSR)
i bought the one without the harness.
but is there a difference between the 2 ground wires??
draxxus07
Sep 24, 2005 12:10 PM
anothersickhatch
May 15, 2004 10:22 PM
jaydm98
Dec 17, 2003 06:33 AM
LsPower
Dec 3, 2002 08:56 AM
