cel code problem
I have an idling problem and the cel code tosse a number 14(electronic air control). How do i fix this? It also tosses another code 91 (fuel tank circuit ). I don't know what this one does except for that it build pressure in my gas tank/cap.
Fuel pump might be going downhill. Maybe.
Check the usual things: fuel filter, plugs, wires, cap, rotor, wiring... You might check our your main relay as well (I don't think the relay throws a code when it goes bad though, but I may be wrong).
