CEL Code
Old Mar 14, 2004 | 08:52 AM
EuN_TeK's Avatar
Default CEL Code
How can you tell if the light flash is long or short?
I had 9 of the same length flashes...
I'm assuming its all long flashes because they didn't seem very quick at all...
and Code 90 seems to be "Evaporative Emission Control System leak detected in the fuel tank area"
What is that?
Is that an unshut fuel cap?
Any help would be nice~
Thank you~
Old Mar 14, 2004 | 09:07 AM
EuN_TeK's Avatar
Default Re: CEL Code (EuN_TeK)
It says if you don't turn the gas cap until you hear 3 clicks you might get a CEL?
So I did that and am resetting the ECU now...
If this doesn't solve the problem, someone please give me some advice...
Old Mar 14, 2004 | 03:25 PM
mikestypeR
Guest
Posts: n/a
if it is a quick split second flash that counts as "1" if it is the long flash like you are saying then that counts as "10" then just add....
if you say you got 9 long flashes then yes that is CEL code 90 ... look it up .... if it is the evaporation tank like you listed in your first post then have someone take a look at it unless you know what your doing
Old Mar 15, 2004 | 04:51 AM
A3LV1N's Avatar
Default Re: CEL Code (mikestypeR)
when will the cel flash to tell u the code? mine cel light came on yesterday.. TIA
Old Mar 15, 2004 | 08:38 AM
EuN_TeK's Avatar
Default Re: CEL Code (A3LV1N)
Well, I reset the ECU and the light didn't come back on...
Should I still have it checked out by someone?
The closest Acura dealership is 1.5 hours from me but there are Honda dealerships... It should be ok to take it to them if I have any problems right? I mean they should know what to do... right?
Old Mar 15, 2004 | 10:32 AM
00MRSi's Avatar
I would just let it go, unless the light comes on again. Make sure to tighten gas cap properly..
Nors
Aug 14, 2006 06:53 PM
G_S_R
May 3, 2004 03:17 PM
jArceo
Oct 14, 2003 05:02 PM
PiYoImuT
Aug 22, 2001 09:59 AM
