cel code ckf sensor
Old Aug 17, 2012 | 05:31 PM
Navy_Kyle's Avatar
Default cel code ckf sensor
ok so my car is throwing a cel for the ckf sensor
and i replaced the sensor and its still throwing the code, the sensor is good i checked that, idk if its my ecu or my wiring from the ecu to the engine harness or something else any ides?
Old Aug 17, 2012 | 05:54 PM
JuicedUpRice's Avatar
Default Re: cel code ckf sensor
check to see if maybe the timing belt ate through some wiring..i have heard of it happening before..
if nobody can step in,i found this if you wanna check it out.dunno if it will help or not,just trying to help.
http://ff-squad.com/wp/?p=309
Old Aug 17, 2012 | 06:26 PM
Navy_Kyle's Avatar
i took it off after i ran the motor, and still nothing i took it off and there was nothing wrong and ill look at it right now thanks man
Old Aug 17, 2012 | 06:28 PM
Navy_Kyle's Avatar
ohh yaa i tried that and it still didnt work
Old Aug 17, 2012 | 07:23 PM
you did reset the ecu after fixing right?
Old Aug 17, 2012 | 07:25 PM
Navy_Kyle's Avatar
yes you just unplug it from the harness and i took the cables off the battery too
Old Aug 18, 2012 | 03:11 AM
HondaPartsHero's Avatar
Technical Hero
Bypass it
http://technet.ff-squad.com/ckftrick.htm
Old Aug 18, 2012 | 02:02 PM
Navy_Kyle's Avatar
i tried it and it didnt work
KashMillien
Jun 20, 2015 03:32 AM
king_pin
Mar 27, 2009 06:43 PM
Dc_Ek
Aug 9, 2006 08:28 AM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
Nerv2g
Aug 10, 2003 08:42 PM
