Would CEL codes 1 and 61 be about the same thing?
My 99 Si, throws a CEL code 61 and i was just wondering if that's the same as code 1, having to replace the primary oxygen sensor, the sensor on the cat?
Code 1- Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
Code 61 - Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
Info taken from cspeedracing.com
Re: Would CEL codes 1 and 61 be about the same thing? (4DoorGeezer)
They refer to the same sensor - yes.
But the method that the ECU used to determine if it was bad is different between the two codes.
Re: Would CEL codes 1 and 61 be about the same thing? (EE_Chris)
okay so jus making sure, i need the same senor as i would to fix code 1 right? Primary Oxygen sensor ? just making sure....
97civic07gsxr
03-27-2009 05:11 PM
Sinner
06-01-2006 08:44 AM
