can i use any year cluster
Old 04-01-2006, 06:09 AM
v-tec maz's Avatar
Default can i use any year cluster
im restoring a gsr, i was just wondering could i use any year cluster from any gsr?
Old 04-01-2006, 06:20 AM
gsr dood's Avatar
Default Re: can i use any year cluster (v-tec maz)
i believe obd1 and obd2 are diffrent harness's. obd1 integra gsr ar 94-95 an obd2 is 96-01 im 90% sure u need the right obd cluster
Old 04-01-2006, 06:30 AM
v-tec maz's Avatar
Default Re: can i use any year cluster (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">i believe obd1 and obd2 are diffrent harness's. obd1 integra gsr ar 94-95 an obd2 is 96-01 im 90% sure u need the right obd cluster</TD></TR></TABLE>
is tehre a way i can tell the difference?
Old 04-04-2006, 08:10 AM
v-tec maz's Avatar
Old 04-04-2006, 08:15 AM
SYTFU Tommy.'s Avatar
actully, the harness is the same. the only problem with the clusters is when you use a 94-97 cluster on a 98+ and vise versa, the gas gauage will not work and some of the lights also since the light placements are different.
Old 04-04-2006, 08:17 AM
v-tec maz's Avatar
Default Re: can i use any year cluster (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay &raquo;</TD></TR><TR><TD CLASS="quote">actully, the harness is the same. the only problem with the clusters is when you use a 94-97 cluster on a 98+ and vise versa, the gas gauage will not work and some of the lights also since the light placements are different. </TD></TR></TABLE>
how could i figure out what year cluster i have?
Old 05-10-2006, 07:36 AM
MAZI's Avatar
well i got baned now im back. yep you were right the gas gauge didnt work. i fixed it, now the seatbelt light doesnt comeon. any write ups on these things?
jv88_dc2
05-10-2010 08:55 PM
MadCityVtec
03-02-2009 10:36 AM
gursh d
10-16-2007 05:56 AM
bunnyhatch93
09-02-2007 09:38 PM
Quick Reply: can i use any year cluster
