can i use any year cluster
Re: can i use any year cluster (v-tec maz)
i believe obd1 and obd2 are diffrent harness's. obd1 integra gsr ar 94-95 an obd2 is 96-01 im 90% sure u need the right obd cluster
Re: can i use any year cluster (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood »</TD></TR><TR><TD CLASS="quote">i believe obd1 and obd2 are diffrent harness's. obd1 integra gsr ar 94-95 an obd2 is 96-01 im 90% sure u need the right obd cluster</TD></TR></TABLE>
is tehre a way i can tell the difference?
actully, the harness is the same. the only problem with the clusters is when you use a 94-97 cluster on a 98+ and vise versa, the gas gauage will not work and some of the lights also since the light placements are different.
Re: can i use any year cluster (tngay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay »</TD></TR><TR><TD CLASS="quote">actully, the harness is the same. the only problem with the clusters is when you use a 94-97 cluster on a 98+ and vise versa, the gas gauage will not work and some of the lights also since the light placements are different. </TD></TR></TABLE>
how could i figure out what year cluster i have?
well i got baned now im back. yep you were right the gas gauge didnt work. i fixed it, now the seatbelt light doesnt comeon. any write ups on these things?
JDMITRTURBO
08-08-2006 05:05 AM
