Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23
Old 02-01-2006, 12:37 PM
Sam92Teg's Avatar
Default Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23
I came along this great buy in the JCWhitney catelog, and wanted all the Integra owners who have been wanting to do their bushings to take a look.
https://honda-tech.com/zerothread?id=1513026 This thread is in the suspension forum.
Old 02-01-2006, 12:39 PM
runeminaEF9's Avatar
Default Re: Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23 (Sam92Teg)
not a bad buy. so.......obviously bushings is what you bought it for....does it work good???
Old 02-01-2006, 12:40 PM
Sam92Teg's Avatar
Default Re: Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23 (runeminaEF9)
Yep
Old 02-17-2006, 09:26 AM
CRXDrew's Avatar
I was under the impression that 1 ton was not enough.
Old 02-17-2006, 09:41 AM
deac's Avatar
if hand pressure is enough i'm pretty sure 1-ton is.
wreckedmyteg's Avatar
Default Re: Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23 (CRXDrew)
Wish I would've seen this before I spent 5 bucks per bushing to have them pressed out (installed energy suspension master kit).
There's 2 per front LCA, 2 per front UCA, and 1 compensator arm bushing each side.
I paid 50 bucks just for the front.
Old 02-17-2006, 10:15 AM
Flexin5's Avatar
Default Re: Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23 (wreckedmyteg)
damn, i would have 1000 uses for that. you guys in the states get all the good deals
Old 02-17-2006, 02:55 PM
mRs_PaNdA's Avatar
That's an awesome find I am gonna have to tell my husband to pick one of those up. So he can finally redo the bushings on my em1
Old 02-17-2006, 06:20 PM
Sam92Teg's Avatar
Default Re: Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23 (mRs_PaNdA)
I just did some of my rear control arm bushings. This press won't remove the original bushings, but it will press in the new ones. I had to torch the originals with a $15 propane torch from Ace hardware, and then I took a hacksaw to cut the outer shell, then an old screwdriver with a hammer to knock the old outer shell out. The press did make easy work out of putting the new bushings back in.
Old 02-19-2006, 08:26 AM
vtecmissle's Avatar
i just lit all mine on fire and scraped them out. Then i pushed all of them in with a vise. Worked just fine.
hackish
34
07-11-2006 08:05 PM
delguiner
12-06-2004 01:47 PM
matix
11-22-2004 05:52 AM
whitelightnin
04-01-2004 11:11 AM
Eggman
08-21-2003 12:38 PM
Quick Reply: Bushing install made easy, now no one has an excuse, 1 ton Arbor Press for $23
